Hi, I am doing a ASZ swap with 6 speed gearbox.
I am almost done with the conversion, but i am stuck.
I want to know, will the golf mk5 2.0 fsi/gti driveshafts work in my Van?
Also will the mounting that sits on the gearbox of a mk5, work for my Van?
6 speed driveshaft *HELP*
2007 1.9 TDI Caddy Panel Van (Pre Facelift)
1994 Golf Mk1 16V
1989 Caddy mk1 2L 8v
1974 Beetle , named Bumblebee (my first car and my show car) Slammed to eart
1994 Golf Mk1 16V
- james400
Re: 6 speed driveshaft *HELP*
Hi to the drive shafts yes they will as long as thay are off a 6 Speed gear box as that is what I have on mine but check that they fit your hubs first tho for the gear box mounts the 6 Speed gear box mount has a 3 bolt mount on the gear box but will go straight on to the original holes on the chassis hope this help
Thank you , that really helped a lot. That's the only thing holding me back from getting this done.james400 wrote: ↑Mon Oct 15, 2018 12:57 pm Hi to the drive shafts yes they will as long as thay are off a 6 Speed gear box as that is what I have on mine but check that they fit your hubs first tho for the gear box mounts the 6 Speed gear box mount has a 3 bolt mount on the gear box but will go straight on to the original holes on the chassis hope this help
1994 Golf Mk1 16V
1994 Golf Mk1 16V
