Touran bases - Simple question
scooby8272
Post by scooby8272 »
I’ve just got some Touran bases for some New seats.
Question is this
When you remove the old caddy seats do you remove the seat and the frame bolted to the floor ?
Does the Touran base fix directly to the caddy floor or the caddy seat frame?
Hope that makes sense,sorry if it’s a simple question
Caddyluv
Re: Touran bases - Simple question
Post by Caddyluv »
Caddy seat and bases out. Touran base and new seats back in. Quite easy.
scooby8272
Thanks Man :D
Liam
Post by Liam »
just make sure you have the bolts that held the touran seats to the touran frame as the caddy bolts are smaller
Build thread here
nodeward
Post by nodeward »
You can get away with using normal hexhead bolts if you don't have the proper vw ones, they are m10's
You might have a problem turning M10 hex head bolts as they locate withing a U shape channel.
Socket head bolts will be better if you can get them.
scooby8272
I have all the bolts from the touran bases both sides and even the screws that hold the drawers in :D
Cheers All
Liam
Post by Liam »
no excuses get them in so
Build thread here
Joeski
Post by Joeski »
sorry to hijack...looking at some audi seats on fleabay and was wondering if i'll get away with just drilling the caddy bases or do I need audi bases? Cheers,
Caddyluv
Post by Caddyluv »
You can drill or use Touran bases.
Liam
Post by Liam »
but speaking from recent experience touran bases are so much handier -
plus if they are low seats they will be very low on caddy bases
Build thread here
Caddyluv
Post by Caddyluv »
I do agree Touran bases are more simple.
JD2k
Post by JD2k »
Agreed! I like the extra storage and they still look oem. My golf R mk7 seats actually sit at the same height, if not slightly lower than the caddy seats on the standard bases.
Liam
Post by Liam »
my passat cc seats are low borderline too low on lowest setting on touran frames
Build thread here
resra22
Post by resra22 »
Joeski wrote: Fri Oct 19, 2018 11:25 am sorry to hijack...looking at some audi seats on fleabay and was wondering if i'll get away with just drilling the caddy bases or do I need audi bases? Cheers,
I am doing the same job myself using Audi A6 leather seats, I have tried using the caddy bases but the centres across the audi runners are 20 mm wider than the caddy bases so you cant just drill out, you would need to weld a bit on to drill into. as others have said the audi seats are a lot lower so you would need to fabricate and weld something to make the caddy bases higher. I bought some touran bases and problem solved, the fixing holes match perfectly onto the caddy floor and on the top for the A6 seats, no drilling needed. The touran bases measure 86mm high at the front compared to 42mm for the caddy, so the height issue is sorted as well. So Touran bases saves a lot of hassle, I just need to sort the wiring now.
