Caddy 4 MFSW ACC not working - please help!
Whitey
Post by Whitey » Tue Nov 06, 2018 1:03 am
Hey guys and gals,
Been a while since I posted or had time to browse the forum due to work and family commitments!
I have a 2016 caddy 4 with ACC. I upgraded the steering wheel to MFSW, new slipring that ticked all the boxes on VAG-COM and downgraded my stalks. Installed everything and the MFSW functions work fine except the ACC. Tbh I never really used the ACC but bugging me it doesn't work as intended!
Genuine Caddy 4 MFSW...
Upgraded from Midline slipring - 5K0 953 569 BB - to Highline slipring 5K0 953 569 AP
Downgraded stalks to 5K0953521AR (or 5K0953502K)
I have VCDS and I think I have done the coding correctly. Perhaps not! Or did i chose the wrong slipring?
I have seen other caddy 4 with working ACC using the 5K0 953 569 BC slipring. This slipring doesn't have the angle sensor which my midline did so chose the AP. Did i pick the wrong one?
Any help massively appreciated :)
Re: Caddy 4 MFSW ACC not working - please help!
Post by Doc » Tue Nov 06, 2018 7:20 am
Do you have any note of your before and after coding, maybe a current autoscan too?
Liam
Post by Liam » Tue Nov 06, 2018 7:37 am
sam im assuming the wheel has the acc button on it ? centre button on left hand side of wheel
Build thread here
Whitey
Post by Whitey » Tue Nov 06, 2018 10:01 am
Morning chaps,
Hi Doc, I have an original scan when I first got the van and I will get a fresh scan done after work and upload. Thank you Image
@Liam
Hey mate, it does have the ACC buttons on the wheel :)
Whitey
Post by Whitey » Thu Nov 29, 2018 7:41 pm
Here is my first and recent autoscan. Any help massively appreciated :)
old
Code: Select all
Wednesday,11,October,2017,17:12:34:00001
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.8.0.1 (x64)
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WV1ZZZ2KZGX124274   License Plate:
Mileage: 14710km-9140mi   Repair Order:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 5F 61
VIN: WV1ZZZ2KZGX124274   Mileage: 14710km-9140miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
5F-Information Electr. -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: OK 0000
Address 01: Engine (J623-DFSD)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 016 GT    HW: 04L 907 309 K
   Component: R4 2,0L EDC   H20 1774
   Revision: 8AH20---
   Coding: 0111001204250D090000
   Shop #: WSC 35110 790 50316
   ASAM Dataset: EV_ECM20TDI01104L906016GT 001003
   ROD: EV_ECM20TDI01104L906016GR_001_VN35.rod
   VCID: 0108BD9890090B4E85-8054
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104)       Labels:. 7E0-907-37x-MK100ESC.clb
   Part No SW: 7E0 907 379 P    HW: 7E0 907 379 M
   Component: ESC           H05 0132
   Revision: 00000000    Serial number: 40756000000433
   Coding: 1079409B9264A4820877027D498625E37900F0
   ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
   ROD: EV_Brake1ESCCONTIVN75XGP2_011_VN35.rod
   VCID: 3F8C7B60A67DBDBEB3-806A
1 Fault Found:
0297 - Steering angle sensor
          B1168 54 [008] - Missing Calibration / Basic Setting
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 117
                    Mileage: 11257 km
                    Date: 2017.01.24
                    Time: 00:20:39
Address 08: Auto HVAC (J301)       Labels:| 3C8-907-336.clb
   Part No SW: 7N0 907 426 L    HW: 7N0 907 426 L
   Component: AC Manuell    H17 0202
   Revision: 00012001
   Coding: 0000001002
   Shop #: WSC 00015 115 00000
   ASAM Dataset: EV_Climatic A01005
   ROD: EV_ClimaBasis_VW32.rod
   VCID: 3D700168AC71AFAEA1-8068
1 Fault Found:
9481200 - Refrigerant Pressure
          B10AB F0 [009] - Too Low
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 132
                    Mileage: 14718 km
                    Date: 2017.10.11
                    Time: 16:42:49
Address 09: Cent. Elect. (J519)       Labels:. 1K0-937-08x-09.clb
   Part No SW: 5K0 937 086 AA    HW: 5K0 937 086 AA
   Component: BCM PQ35 M+   122 0183
   Revision: BD122001
   Coding: 491A583EC037E16A08880082940001640351000842228260648087000041
   Shop #: WSC 35110 377 00146
   VCID: 73E4E750D2B529DE87-8026
   Subsystem 1 - Part No: 2K2 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 03031  26  0512
   Coding: 009795
   Subsystem 2 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 100316 03  37  0059
   Coding: 0228DD
   Subsystem 3 - Part No: 7N0 951 172
   Component: Sensor, DWA 0  005 0502
   Coding: 000000
   Subsystem 4 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H05 1501
   Coding: 000000
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-283.clb
   Part No SW: 1K8 919 465     HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0479
   Revision: --------    Serial number: 39291606403471
   Coding: 0001050001
   ASAM Dataset: EV_EPHVA14VW364GP00 001006
   ROD: EV_EPHVA14VW364GP00.rod
   VCID: 76E2DE44C9C73CF6A0-8022
1 Fault Found:
1079058 - Center Rear Left Parking Aid Sensor
          B1077 12 [008] - Short to Plus
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 117
                    Mileage: 14247 km
                    Date: 2017.08.22
                    Time: 00:26:59
Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
   Part No SW: 2K5 959 655     HW: 2K5 959 655
   Component: VW10Airbag019 008 0016
   Revision: --------    Serial number: 003QV001WAGX
   Coding: 000000000000000000000000000000003139
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 79F8D578F8D9538ECD-802C
   Crash sensor for side airbag: driver side:
   Serial number: 3497ARB405J3U9U4393I
   Crash sensor for side airbag: front passenger side:
   Serial number: 3507ARB405J3U47EC11Y
1 Fault Found:
9439771 - Front Passenger's Side Airbag Igniter
          B100A 1B [136] - Resistance Too High
          MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 14245 km
                    Date: 2017.07.30
                    Time: 21:15:16
Address 16: Steering wheel (J527)       Labels:| 5K0-953-569.clb
   Part No SW: 1K5 953 521 CL    HW: 5K0 953 569 BB
   Component: LENKS.MODUL   018 0230
   Revision: FF010042    Serial number: 20160304200615
   Coding: 4080160010
   ASAM Dataset: EV_SMLSNGVOLWSR8C 001001
   ROD: EV_SMLSNGVOLWSR8C.rod
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 2K5 920 966 A    HW: 2K5 920 966 A
   Component: KOMBI         H04 1009
   Serial number: 00000000000000
   Coding: 480A001200
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05730
   ROD: EV_Kombi_UDS_VDD_RM09_005_VN35.rod
   VCID: 336427509A3569DE47-8066
1 Fault Found:
13654544 - Databus
          U1121 00 [009] - Missing Message
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 132
                    Mileage: 14718 km
                    Date: 2017.10.11
                    Time: 17:06:16
Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 BE    HW: 7N0 907 530 AL
   Component: J533  Gateway H58 1673
   Revision:   H58       Serial number: 160316F1002270
   Coding: 357421
   VCID: 74E6E44CD7BB2EE69E-8020
3 Faults Found:
01305 - Databus for Infotainment
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 1
                    Fault Frequency: 18
                    Reset counter: 171
                    Mileage: 14249 km
                    Time Indication: 0
                    Date: 2017.09.03
                    Time: 00:00:02
00469 - Infotainment Databus in Single Wire Operation
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101011
                    Fault Priority: 3
                    Fault Frequency: 254
                    Reset counter: 168
                    Mileage: 14249 km
                    Time Indication: 0
                    Date: 2017.09.04
                    Time: 09:29:06
03158 - Control Module for Information Electronics 1 (J794)
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 117
                    Mileage: 14249 km
                    Time Indication: 0
                    Date: 2017.09.04
                    Time: 09:29:10
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H04 1009
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
   ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
   VCID: 6ADAFA348D7FE81634-803E
Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MAX3.clb
   Part No SW: 2K5 959 701     HW: 2K5 959 701
   Component: Tuer-SG         009 2144
   Coding: 0131632
   VCID: 71E8ED5868A91BCE75-8024
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 140    3501
   Revision: 00H22000
   VCID: 397815787059938E8D-806C
Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MAX3.clb
   Part No SW: 2K5 959 702     HW: 2K5 959 702
   Coding: 0131632
   VCID: 72EAE2546DAF20D68C-8026
Address 5F: Information Electr.
Cannot be reached
Address 61: Battery Regul. (J840)       Labels:. 1K0-907-534.clb
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AL
   Component: Batt.regelung H58 1673
   Coding: 030F1873
   VCID: 71E8ED58A8A91BCE75-8024
   Subsystem 1 - Part No SW: 1K0 915 181 K    HW: 1K0 915 181 K
   Component: J367-BDM  H07 0223
   Serial number: 43069835248761720259
End-------------------------(Elapsed Time: 02:32)--------------------------
latest scan
Code: Select all
Wednesday,28,November,2018,11:35:38:45243
VCDS Version: 18.9.0.2 (x64)
Data version: 20180927 DS296.0
www.Ross-Tech.com
Mileage: 34550km-21468mi   Repair Order:
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 5F 61 6C
VIN: WV1ZZZ2KZGX124274   Mileage: 34550km-21468miles
01-Engine -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: Cannot be reached 1100
   Component: R4 2,0L EDC   X20 1774
   Revision: 8AX20---
   Shop #: WSC 92521 052 00000
   VCID: 0109DB3390B9B142DA-8054
3 Faults Found:
21472 - Databus
          U1122 00 [047] - Implausible Message
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 26324 km
                    Date: 2018.05.16
                    Time: 08:32:08
                    Engine speed: 0.00 /min
                    Normed load value: 0.0 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 65 °C
                    Intake air temperature: 61 °C
                    Ambient air pressure: 1020 mbar
                    Voltage terminal 30: 12.160 V
                    Unlearning counter according OBD: 40
                    ACC variants-Bits 0-7: 0
                    Cruise Control System (CCS): status-Bits 0-7: 7
                    Cruise control switch actuation-Bits 0-7: 0
                    Cruise control switch actuation-Bits 0-7: 32
                    ACC variants (coding)-Bits 0-7: 1
                    Acceleration: 0.000 m/s²
15733 - SCR NOx Catalyst Bank 1
          P20EE 00 [096] - Efficiency too Low
          Intermittent - Not Confirmed - Tested Since Memory Clear
17923 - Databus
             Freeze Frame:
                    Fault Priority: 2
                    Mileage: 26324 km
                    Date: 2018.05.16
                    Time: 08:32:08
                    Drivetrain coordinator: ACC fault status-Bits 0-7: 0
                    Drivetrain coordinator: brake fault status-Bits 0-7: 0
                    Drivetrain coordinator: brake function status-Bits 0-7: 32
                    Drivetrain coordinator: brake function status-Bits 0-7: 0
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104)       Labels: 7E0-907-37x-MK100ESC.clb
   ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
   VCID: 3F8D1DCBA6CD07B2EC-806A
   Revision: 00012001
   Coding: 0000001002
   VCID: 3D7167C3ACC115A2FE-8068
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 10
                    Mileage: 26327 km
                    Date: 2018.05.16
                    Time: 09:09:25
   Revision: BD122001
   Coding: 411A5838C025E16A08880082940001640379000842228660648087000041
   VCID: 73E581FBD20593D2D8-8026
   Coding: 009795
   Coding: 0228DD
   Coding: 000000
   Coding: 000000
3 Faults Found:
01504 - Bulb for License-Plate Light (X)
            010 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00101010
                    Fault Priority: 2
                    Fault Frequency: 171
                    Reset counter: 67
                    Mileage: 26359 km
                    Time Indication: 0
                    Date: 2018.05.16
                    Time: 18:34:07
             Freeze Frame:
                        Term 15 On
                    Voltage: 14.20 V
                        ON
                        ON
                        ON
                        OFF
                        OFF
02394 - Parking Light Left Front (M1)
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 10
                    Mileage: 26324 km
                    Time Indication: 0
                    Date: 2018.05.16
                    Time: 08:36:35
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.10 V
                        ON
                        ON
                        ON
                        OFF
                        OFF
02395 - Parking Light Front Right (M3)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 10
                    Mileage: 26324 km
                    Time Indication: 0
                    Date: 2018.05.16
                    Time: 08:36:35
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.10 V
                        ON
                        ON
                        ON
                        OFF
                        OFF
   Coding: 0001140001
   ROD: EV_EPHVA14VW364GP00_VW36.rod
   VCID: 76E3B8EFC97786FAFF-8022
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 12
                    Reset counter: 5
                    Mileage: 31491 km
                    Date: 2018.09.11
                    Time: 14:39:04
12718592 - Databus
          [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 32
                    Mileage: 34556 km
                    Date: 2018.11.28
                    Time: 12:30:15
   ROD: EV_AirbaVW10BPAVN750_VW12.rod
   VCID: 79F9B3D3F869E98292-802C
   Part No SW: 5K0 953 501 DP    HW: 5K0 953 569 AP
   Component: LENKS.MODUL   016 0180
   Revision: FF010042    Serial number: 20160321300783
   Coding: 210A440000
   Shop #: WSC 00020 999 00000
   ASAM Dataset: EV_VW360SteerWheelUDS A03004
   ROD: EV_VW360SteerWheelUDS.rod
   VCID: 7BF5A9DBF255DB9280-802E
   Multifunction steering wheel control module:
   Subsystem 1 - Part No SW: 2K0 959 442 A    HW: 2K0 959 442 A  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAT  H04 0020
   Serial number: 0641514203601412BL1B
   Coding: 2C0000
2 Faults Found:
226839 - Turn Signal Switch
          B1144 11 [009] - Short to Ground
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 10
                    Mileage: 26324 km
                    Date: 2018.05.16
                    Time: 08:32:08
335876 - Powertrain Databus
          U0002 00 [009] - No Communications
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 10
                    Mileage: 26324 km
                    Date: 2018.05.16
                    Time: 08:32:08
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Coding: 4800200200
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW25.rod
   VCID: 336541FB9A85D3D218-8066
1 Fault Found:
13654544 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Reset counter: 32
                    Mileage: 26324 km
                    Date: 2018.05.16
                    Time: 08:32:08
   Coding: 357423
   VCID: 74E782E7D70B94EAC1-8020
2 Faults Found:
02873 - Control Module for Back-Up Camera (J772)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 10
                    Mileage: 26324 km
                    Time Indication: 0
                    Date: 2018.05.16
                    Time: 08:32:14
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 10
                    Mileage: 26324 km
                    Time Indication: 0
                    Date: 2018.05.16
                    Time: 08:32:14
   Coding: 000000
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADB9C9F8DCF521A6B-803E
   Coding: 0131632
   VCID: 71E98BF36819A1C22A-8024
   Revision: 00H22000
   VCID: 397973D370E92982D2-806C
   Coding: 0131632
   VCID: 72EB84FF6D1F9ADAD3-8026
Cannot be reached
   Coding: 030F1873
   VCID: 71E98BF3A819A1C22A-8024
Address 6C: Back-up Cam.
Cannot be reached
End-------------------------(Elapsed Time: 02:56)--------------------------
Thursday,29,November,2018,18:15:43:45243
www.Ross-Tech.com
   Revision: 8AX20---
2 Faults Found:
21472 - Databus
          U1122 00 [039] - Implausible Message
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 34556 km
                    Date: 2018.11.29
                    Time: 19:03:22
                    Coolant temperature: 9 °C
                    Intake air temperature: 10 °C
                    Ambient air pressure: 990 mbar
                    Voltage terminal 30: 11.860 V
17923 - Databus
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 34556 km
                    Date: 2018.11.29
                    Time: 19:03:21
   Revision: 00012001
   Coding: 0000001002
   Revision: BD122001
   Coding: 009795
   Coding: 0228DD
   Coding: 000000
   Coding: 000000
   Coding: 0001140001
2 Faults Found:
          B1077 12 [009] - Short to Plus
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 32
                    Mileage: 34556 km
                    Date: 2018.11.29
                    Time: 19:09:21
12718592 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 32
                    Mileage: 34556 km
                    Date: 2018.11.29
                    Time: 19:03:22
   Coding: 210A444000
   Shop #: WSC 00020 999 12345
   Coding: 2C0000
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 32
                    Mileage: 34556 km
                    Date: 2018.11.29
                    Time: 19:03:21
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 32
                    Mileage: 34556 km
                    Date: 2018.11.29
                    Time: 19:03:21
   Coding: 4808200200
1 Fault Found:
13654544 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 32
                    Mileage: 34556 km
                    Date: 2018.11.29
                    Time: 19:03:21
   Coding: 357423
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 32
                    Mileage: 34556 km
                    Time Indication: 0
                    Date: 2018.11.29
                    Time: 19:03:27
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 32
                    Mileage: 34556 km
                    Time Indication: 0
                    Date: 2018.11.29
                    Time: 19:03:27
   Coding: 000000
   Coding: 0131632
   Revision: 00H22000
   Coding: 0131632
Cannot be reached
   Coding: 030F1873
Cannot be reached
End-------------------------(Elapsed Time: 02:42)--------------------------
Thursday,29,November,2018,18:29:35:45243
www.Ross-Tech.com
   Revision: 8AX20---
2 Faults Found:
21472 - Databus
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 34556 km
                    Date: 2018.11.29
                    Time: 19:03:22
17923 - Databus
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 4
                    Mileage: 34556 km
                    Date: 2018.11.29
                    Time: 19:03:21
   Revision: 00012001
   Coding: 0000001002
   Revision: BD122001
   Coding: 009795
   Coding: 0228DD
   Coding: 000000
   Coding: 000000
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 32
                    Mileage: 34556 km
                    Time Indication: 0
                    Date: 2018.11.29
                    Time: 19:15:35
             Freeze Frame:
                        Term 15 Off
                    Voltage: 11.55 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 32
                    Mileage: 34556 km
                    Time Indication: 0
                    Date: 2018.11.29
                    Time: 19:15:35
             Freeze Frame:
                        Term 15 Off
                    Voltage: 11.55 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
   Coding: 0001140001
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 32
                    Mileage: 34556 km
                    Date: 2018.11.29
                    Time: 19:09:21
12718592 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 32
                    Mileage: 34556 km
                    Date: 2018.11.29
                    Time: 19:22:35
   Coding: 210A440000
   Coding: 2C0000
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 32
                    Mileage: 34556 km
                    Date: 2018.11.29
                    Time: 19:03:21
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 32
                    Mileage: 34556 km
                    Date: 2018.11.29
                    Time: 19:03:21
   Coding: 4808200200
1 Fault Found:
13654544 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 32
                    Mileage: 34556 km
                    Date: 2018.11.29
                    Time: 19:03:21
   Coding: 357423
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 32
                    Mileage: 34556 km
                    Time Indication: 0
                    Date: 2018.11.29
                    Time: 19:03:27
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 32
                    Mileage: 34556 km
                    Time Indication: 0
                    Date: 2018.11.29
                    Time: 19:03:27
   Coding: 000000
   Coding: 0131632
   Revision: 00H22000
   Coding: 0131632
Cannot be reached
   Coding: 030F1873
Cannot be reached
