OBDeleven pro
Billyblunt
OBDeleven pro
Post by Billyblunt » Sun Nov 18, 2018 4:53 pm
Has anyone used one if these to unlock any hidden on their Caddy's? I know it's a diagnostic tool but was hoping it would allow me to access anything hidden within the display or infotainment system.
caddychris2002
Re: OBDeleven pro
Post by caddychris2002 » Sun Nov 18, 2018 5:11 pm
I've done a few bits but nothing major. It's good not as supported as VCDS but its also a fifth of the cost
Billyblunt
Re: OBDeleven pro
Post by Billyblunt » Sun Nov 18, 2018 5:32 pm
Yes that's what I thought. I'm a total technophobe & the thought of writing any codes breaks me out in a cold sweat so the idea of using an app is very appealing. I don't think I'd ever use it for more than giving me an idea if any faults develop & just to look at some engine performance stats.
caddychris2002
Re: OBDeleven pro
Post by caddychris2002 » Mon Nov 19, 2018 4:48 pm
In that case go for it the pro version tells you with the kit connected in thw van what mods you can do like turn stuff off or on Etc
Billyblunt
Re: OBDeleven pro
Post by Billyblunt » Mon Nov 19, 2018 5:27 pm
Thanks for the reply @caddychris2002. Been checking out some YouTube on the VCDS & it's certainly throwing up some interesting stuff. I imagine it's a bit of a rabbit hole to go down :)
missyR
Re: OBDeleven pro
Post by missyR » Tue Nov 20, 2018 12:48 am
caddychris2002 wrote:In that case go for it the pro version tells you with the kit connected in thw van what mods you can do like turn stuff off or on Etc
Would this let me switch on my heated seats once installed?
caddychris2002
Re: OBDeleven pro
Post by caddychris2002 » Tue Nov 20, 2018 12:01 pm
missyR wrote:Would this let me switch on my heated seats once installed?
Sure can MissyR
missyR
Re: OBDeleven pro
Post by missyR » Tue Nov 20, 2018 12:12 pm
caddychris2002 wrote:Sure can MissyR
Ooooo I had a wee research in the middle of the night and looks rather interesting it must be worth a punt.
Billyblunt
Re: OBDeleven pro
Post by Billyblunt » Tue Nov 20, 2018 1:37 pm
Just pulled the trigger on the pro version, £55or there abouts with 200 credits direct from their website so no dodgy software etc. Let's see what I can do with it but you can certainly turn heated seats on with it.
missyR
Re: OBDeleven pro
Post by missyR » Tue Nov 20, 2018 5:52 pm
Billyblunt wrote:Just pulled the trigger on the pro version, £55or there abouts with 200 credits direct from their website so no dodgy software etc. Let's see what I can do with it but you can certainly turn heated seats on with it.
Yeah I think I'll be doing the same. Can you post up your thoughts of it when you get it. As I'm interested after what I read/seen on the web it looks good for what I'd need it for and save me a fortune in garage bills x
Billyblunt
Re: OBDeleven pro
Post by Billyblunt » Tue Nov 20, 2018 7:41 pm
Yes of course. I'll be initially use it to see what all the spec of bits & pieces are & to see if I can get in to the MFD & change a few things or unlock it in some way. I know that the pro version now allows for long coding so you can change things that way & it wont cost any credits.
missyR
Re: OBDeleven pro
Post by missyR » Tue Nov 20, 2018 8:59 pm
Billyblunt wrote:Yes of course. I'll be initially use it to see what all the spec of bits & pieces are & to see if I can get in to the MFD & change a few things or unlock it in some way. I know that the pro version now allows for long coding so you can change things that way & it wont cost any credits.
Fantastic it's on the to buy list... which is really long with this van ha!
Billyblunt
Re: OBDeleven pro
Post by Billyblunt » Mon Nov 26, 2018 9:28 pm
Well it arrived today & I had a quick 5 minute play before i headed to work. What quickly became apparent is that you need to sit down & read up on how to actually use the thing as it doesn't come with any instructions, nich, nothing! So I can't really give a good critique at the moment. The app does look swish & the graphics appealing. What I did find useful was that it does identify what units/moduals you have fitted so I can at least see what I need to upgrade. On the downside it also showed me how much it doesn't have that I hoped that was just hidden & not switched on.
Once I've delved in to it a bit more, I'll have a better idea what it's capable of.
missyR
Re: OBDeleven pro
Post by missyR » Mon Nov 26, 2018 10:18 pm
Fantastic! Mines is enroute too expecting it early next week. I feel I will be the same as I have a baseline van
Thankfully though this will not deter me from wanting to upgrade stuff it will just cost a little bit more for modules and looms.
Berger
Re: OBDeleven pro
Post by Berger » Tue Nov 27, 2018 8:43 pm
Would I be able to use this to turn off seat belt chimes and activate central locking when van starts moving etc?
On my 3rd caddy now :lol:
Blackberry Mk4 150 dsg Highline factory xenon lights, heated seats, acc, high beam assist, 17” rockhampton wheels, car mirrors,
Rad sile rail cover, caddy life armrest, rear wiper delete fully colour coded , gloss black grills (a lot more to follow)
Instagram caddyad7
