VCDS
Sean1066
VCDS
Post by Sean1066 » Wed Nov 21, 2018 9:40 pm
Hi guys and girls
How hard is it to recode using VCDS?
Is it idiot proof?
Thanks you in advance Sean
Remapped to 140, Colour coded bumpers, VW Cadiz 18s Vanstyle roof rails, Vanstyle bumper protect.
viewtopic.php?f=13&t=36851
Liam
Re: VCDS
Post by Liam » Wed Nov 21, 2018 9:43 pm
definitely not idiot proof you could do harm if you werent careful
Build thread here
Sean1066
Re: VCDS
Post by Sean1066 » Wed Nov 21, 2018 10:01 pm
Thanks Liam
Sean1066
Re: VCDS
Post by Sean1066 » Thu Nov 22, 2018 8:34 pm
Is there anyone local to Devon that can code in a new steering wheel or show me how to do it ?
JimR
Re: VCDS
Post by JimR » Sat Nov 24, 2018 6:43 pm
Also consider ODBeleven, I just received mine and it looks really easy to use at first test.
I had removed the passenger seat and was driving with Airbag failure and it resets all failures at a press of one button
JimR
Sean1066
Re: VCDS
Post by Sean1066 » Sat Nov 24, 2018 7:26 pm
where did you get ODBeleven from JimR?
can it code in my MFSW because that's what i need VCDS for :?
Billyblunt
Re: VCDS
Post by Billyblunt » Sat Nov 24, 2018 7:47 pm
Ooh, that's what I'm hoping for as I'll eventually want to fit a MFSW as well as seeing what I can unlock on the dash.
VOLKS HAUS
Re: VCDS
Post by VOLKS HAUS » Tue Nov 27, 2018 8:55 pm
If you have a genuine Ross tech VCDS you can register with them and they provide user support and a great forum.
They have helped us with control maps for an Aventador.
