Idiot needs advice fitting dash storage
Good afternoon
I've ordered the dash storage box for my 2011 Caddy Maxi (ex British Gas), part: 2K585832975/R
I had a quick look at removing the factory one, but I'm not sure how to remove it properly and fit the new one!
I am sure it is just a case of applying a bit of leverage, but can anyobe here tell me if it just pops out using a flat head screwdriver, or is there much more to it?
I don't want to get annoyed and smash up the dash.
CADOIBADOI
CADOIBADOI
- tommyzooom
Re: Idiot needs advice fitting dash storage
Two clips furthest from the windscreen need released, there are two holes for a small screwdriver.
If you've the new part, you should be able to work it out from that.
You will need to release the metal clips.
There are two slots on the dash tray where you can get a narrow pick tool in. You should be able to see it on your new lidded top tray.
Is the lidded storage box still available from VW then? What was it cost and part no if so please?
- Sean1066
Hi Cadoibadoicadoibadoi wrote: ↑Sat Nov 24, 2018 3:28 pmGood afternoon
CADOIBADOI
If don’t mind telling me.
Where did you get the dash storage from I been looking for weeks and can’t seem to find one
Remapped to 140, mk5 golf mfsw, Colour coded bumpers, VW Cadiz 18s, wheels, Vanstyle bumper protecter, Vanstyle rear spoiler, Vanstyle roof rails, After market fog lights. Lowered on V-Maxx, Audi A3 S Line seats on Touran bases, Audi TT air vents
viewtopic.php?f=13&t=36851
Please do not use a screwdriver to pry it out as you will damage the surrounding dashboard plastic trim. Purchase and use plastic trim removal tools which are cheap to buy and they will also have many other uses in the future for other trim removal Then after taking purchase of the new dash storage unit note/reference where the two nearest to you metal retaining clips are. This will give you the precise location where to insert two really thin plastic trim removal tools. Push these two thin plastic removal tools down at least an inch and half at the metal retaining clips locations as per reference from your new dash storage unit and then get your fingers in the existing dash storage tray front wall nearest to you (whilst sat in the drivers seat) and pull up with a little bit of force but not excessively and it should release. If it does not release you have not got the trim removal tools inserted enough or they are inserted in the wrong locations. I myself used two eating knives to release mine although I did put a few layers of duct/duck tape on top of each other along the front edge (Nearest to you when sat in the drivers seat) on the dashboard to prevent and protect any marring/damage of the surrounding plastic dashboard from the use of eating knives as trim removal tools when removing but this method of removal is at your own risk. I can't explain it any better than that really. I will say that they can be a bit tight to get out but just take your time to avoid damage to the dashboard plastic. You can do it.
Hi There
I ordered off EBay from Germany, the Ebay part number is: 382184206023 £129.38 including DHL carriage. I was out the first time they tried to deliver but they came back next day, very good parcel tracking using German DHL website.
I've attached pictures of the stickers from the box and the delivery note. 99.9% sure its a genuine part.
Thanks everyone for the good advice, once I get round to fitting it I'll take a few pics and post them as well in case it helps anyone.
Cheers.
Cheers.
Hi
The kitchen knife method works well, doesn't damage the dash if you're careful. You can see the clips once you've pushed the trim back slightly which helps!.
- The polisher
Got mine on German eBay from breakers loads there total price was 44 Euro mine is the one with the long clip handy for holding invoices
Touran seats, Touran Console, Touran carpets, Touran Door cards, Spoiler, German Plates, RCD 330, carpeted and insulated, TDI Mats, Stance lowering Kit, VW Mk6 Steering wheel, T6 Steelies, Bargain Sunvisor, Bragan Roof Rails,Touran mirrors
Instagram:HG_Metal_Polishing_13
Facebook: HG Metal Polishing
www.hgmetalpolishing.com
Ireland
Ireland
Wow they look smart and useful will it fit a 2010 pre face ?
Remapped
Side rail cover
18” Audi alloys
Facelift seats
Tinted windows
And much more too add soon
Side rail cover
18” Audi alloys
Facelift seats
Tinted windows
- The polisher
Yip mines a 2006 up to 2010 all the same as far as i know
Ireland
Ireland
