Help with an odd rattle.
GunnerMTB
Post by GunnerMTB » Wed Nov 28, 2018 6:29 pm
Can someone help me diagnose this odd rattle please?
The rally van has started with a strange little rattle that only happens when cruising on a motorway at a constant speed around 60-70 . The rattle comes in for about 10 seconds and then disappears again, it sounds like it's coming from the passenger side behind the dash.
When the rattle starts it doesn't change with revs.
I've done about 300 miles today and it's done it around 5 times that I've noticed.
There are no other rattles or problems, the van drives lovely, no clutch problems or rattles at idle etc.
Bit confused as to what it could be?
Caddyluv
Re: Help with an odd rattle.
Post by Caddyluv » Wed Nov 28, 2018 6:58 pm
Do you have a glove box?
GunnerMTB
Post by GunnerMTB » Wed Nov 28, 2018 7:24 pm
Caddyluv wrote:Do you have a glove box?
No buddy just the open shelf thingy :)
GunnerMTB
Post by GunnerMTB » Wed Nov 28, 2018 7:32 pm
It sounds like a heat shield rattle but it seems to last for a consistent 10 seconds (ish) so I'm not sure.
PaulC61
Post by PaulC61 » Wed Nov 28, 2018 7:59 pm
Do you have climate control?. Could be something like a damper motor making the noise when controlling the temp.
GunnerMTB
Post by GunnerMTB » Wed Nov 28, 2018 10:56 pm
Yeah I do have single zone climate actually, you might be onto something there. It seems to have no effect on the van and doesn't respond to throttle input or pressing the clutch in etc.
Sportvan
Post by Sportvan » Thu Nov 29, 2018 6:49 am
My recirculating flap motor makes a rattling noise when in auto, hacks me off. And VW aren’t interested in fixing it as it’s not broken.
Caddy Highline 150tdi Dsg etc etc
PaulC61
Post by PaulC61 » Thu Nov 29, 2018 8:10 am
GunnerMTB
Post by GunnerMTB » Thu Nov 29, 2018 5:12 pm
Any chance of posting that link again please? It doesn't seem to work. What's the recirculating flap when it's at home?
PaulC61
Post by PaulC61 » Thu Nov 29, 2018 5:54 pm
https://volkswagen.7zap.com/en/rdw/caddy/ca/2015-690/
https://nemigaparts.com/cat_spares/etka/volkswagen/
One of these 2 links should work, just navigate to the appropriate model then what part you need to look at. If not I will post a screen shot later.
