08 plate bls engine
astraman18
08 plate bls engine
Post by astraman18 » Sat Dec 01, 2018 12:06 pm
What's the problem with this engine apart from throwing rods . ?
Any electrical issues
Mine won't start. Threw up crank sensor .
shanky887614
Re: 08 plate bls engine
Post by shanky887614 » Sat Dec 01, 2018 5:25 pm
are you getting any rpm on the dash?
is the cluster lighting up
Sent from my ASUS_X00ID using Tapatalk
astraman18
Post by astraman18 » Mon Dec 03, 2018 5:26 pm
shanky887614 wrote:are you getting any rpm on the dash?
Clusters light up .
Rpm moves .
If l spray brake cleaner into the throttle body it runs. Seams like a fuel issue .
Post by Doc » Mon Dec 03, 2018 5:34 pm
When you say it 'threw up" the crank sensor, what exactly was the fault?
The crank sensor needs to read properly in relation to the cam sensor to allow the engine to fire. I'd say solving the crank sensor fault will solve your problem.
astraman18
Post by astraman18 » Mon Dec 03, 2018 5:47 pm
Doc wrote:When you say it 'threw up" the crank sensor, what exactly was the fault?
Sorry meant to be cam sensor .
Now l 've changed the sensor and the fault has gone . But still won't start .
Dropped the tank to make sure the pump is clean .pump is dirty so going to clean it .But it's priming up to the fuel filter.
astraman18
Post by astraman18 » Tue Dec 04, 2018 4:40 pm
It's getting serious now. But a full working pump on still won't start. Time to get the injectors out and check them ? Can any injectors go in out of a 1.9 ?Image
shanky887614
Post by shanky887614 » Tue Dec 04, 2018 8:32 pm
technically yes but some models especially the arl/asz and blt etc use larger cc injectors so it will run lumpy
the map can be adjusted to suit though.
get it checked first, there is workshop manuals to check if the injector seals are shot and if the seals are fine it could be the loom etc.
i had that issue when i had a worn cam+bad tappets
astraman18
Post by astraman18 » Wed Dec 05, 2018 6:16 am
I 've changed the loom in the head already .
Never thought about a worn cam . It has got high mileage aswell . In the 200k bracket .
Where will l find the info about the injector conditions?
