Window issue
Ash1987
Window issue
Post by Ash1987 » Sat Dec 01, 2018 9:49 pm
Just recently brought a caddy, and I have one issue with my passenger side window. I don’t no if the windows run off separate fuses but my drivers side works fine, but the other side doesn’t at all. Neither does electric mirror on that side, witch made me think is it a fuse or something more technical. If anyone could be helpful and possibly point me in the write direction would be appreciated
shanky887614
Re: Window issue
Post by shanky887614 » Sat Dec 01, 2018 10:50 pm
get it scanned with vcds.
the mirror is plugged into the window regulator so if the window doesnt move and you cant adjust your mirror id start there
Sent from my ASUS_X00ID using Tapatalk
Ash1987
Re: Window issue
Post by Ash1987 » Sat Dec 01, 2018 10:55 pm
Cheers bud, I take it that don’t run off separate fuses then ?
shanky887614
Re: Window issue
Post by shanky887614 » Sat Dec 01, 2018 11:12 pm
no im sure the door control module supplies power to them
check fuse 49 under the steering wheel.
it should be 10 from the left (top row) should be a 10amp
Ash1987
Re: Window issue
Post by Ash1987 » Sat Dec 01, 2018 11:16 pm
Where is this? Is it something I can easily do myself?
Ash1987
Re: Window issue
Post by Ash1987 » Sat Dec 01, 2018 11:18 pm
I’ll check tomorrow cheers bud!
Ash1987
Re: Window issue
Post by Ash1987 » Sun Dec 02, 2018 2:37 pm
Just looked at my fuse box and it seems a little short of fuses. And the 10th fuse is not there ! Image
Ash1987
Re: Window issue
Post by Ash1987 » Mon Dec 03, 2018 6:02 pm
Do you think this is why my window and mirror is not working or does it look normal?
shanky887614
Re: Window issue
Post by shanky887614 » Mon Dec 03, 2018 7:17 pm
check all the fuses in there, which fuse it is can vary on year and model etc.
(looks like you are missing some fuses though)
Ash1987
Re: Window issue
Post by Ash1987 » Mon Dec 03, 2018 7:21 pm
Mines 64 plate 1.6 bluemotion andIt’s the fuse for my passenger side mirror and wing mirror! Will it effect anything if I pull random ones in and out ?
Re: Window issue
Post by Doc » Mon Dec 03, 2018 8:12 pm
Both drivers and passengers side door control and window motors use the same two fuses. If it's working on one side it's not a fuse problem.
The door control module takes care of window, mirror and lock operations on that door. Is your central locking working on that door?
Ash1987
Re: Window issue
Post by Ash1987 » Mon Dec 03, 2018 9:26 pm
Ok just had a quick look and I locked my van using the key and you were wright the passenger door doesn’t lock.
What’s your thoughts on this because on the drivers side my window works but not the passenger side on the main controller? Is this a big job?.
Re: Window issue
Post by Doc » Mon Dec 03, 2018 11:43 pm
It may be something simple, just a matter of breaking it down in methodical fashion.
First step, if it were mine, would be to test for voltage supply at the A-pillar socket or at the door control module.
Ash1987
Re: Window issue
Post by Ash1987 » Thu Dec 27, 2018 1:53 pm
Right I’ve managed to get a spare 5 minutes to myself.So I took my door panel off, and checked my main power feed with a voltage reader and there was no power going to the door at all.
My next idea was to have a look in my fuse box, as you can see from my previous post I had a few short in there. Anyway I manage to locate my drivers side fuse, and either side of that was empty, so I just moved it over and BINGO it was the fact there wasn’t one bloody in there.
I just can’t understand why there wasn’t one in there and why the previous owner had left it like this but I’m all sorted and thanks for your help guys
