Scared to lower the workvan
crxftyyy
Post by crxftyyy » Wed Jan 02, 2019 10:23 pm
Hi all, not really in the know with all things lowering. After fitting my touran bumper to my workvan I'm having trouble resisting the urge to lower it,my only problem being it is a working van and I carry quite a fair bit of kit including a water tank and I'm worried a set of coilovers or lowering springs wouldn't hold up to the weight. Can anyone enlighten me? Pic below as an idea, not thinking of slamming it but I've a set of 17s in the pipeline and want them to sit a little nicerImage
Sent from my CLT-L09 using Tapatalk
mikenorman
Post by mikenorman » Thu Jan 03, 2019 8:35 am
I carry a 250kg water tank in mine and in summer I’ll additionally have about another 50kg in gardening tools. I’d probably say with all the bits and bobs I carry at times it’s probably up at around 400kg and don’t have any problems on vmaxx coilovers. The fronts pretty low and the backs on the lowest setting.
The pic is of it with no weight in. 400kg probably drops it about 5mm further but if anything it stiffens it up. I’d get it slammed if I were you ImageImageImageImage
Barbel330
Re: Scared to lower the workvan
Post by Barbel330 » Thu Jan 03, 2019 8:42 am
I wouldn’t worry too much, just do it.
Mine is used as my work van and carries a lot of weight permanently, then it also carries my fishing gear regularly too. I dread to think how much weight is in there. It drives no different when it’s full and the amount it drops when fully loaded is minimal.
Work gear and fishing gear.
How it sits with just my work gear.
Instagram: @y_5cuf
Caddyluv
Post by Caddyluv » Thu Jan 03, 2019 9:33 am
Run a cleaning business out of mine.
crxftyyy
Post by crxftyyy » Thu Jan 03, 2019 10:34 am
Thanks for the help everyone. Might have to save for my birthday after skinting myself so far
Sean1066
Post by Sean1066 » Thu Jan 03, 2019 12:24 pm
I use mine for work and I have lowered mine.
I can still carry the same as before.
Before Image
AfterImage
My build thread
james400
Post by james400 » Thu Jan 03, 2019 1:06 pm
I had my fully built vxr engine in the back for a week and didn't have any problems and my is o coil overs ImageImage
stevegray1977
Post by stevegray1977 » Thu Jan 03, 2019 1:11 pm
Guys - I'm quite new to all this. My van is an ex - BG van and the suspension is really high. I have no idea how to lower it? I did call a couple if garages but they said I needed to buy a kit?
The wheels are still the original steel wheels - so eventually I want to buy some new alloys - 18inch etc, so wasn't sure I would need it lowered as much with bigger wheels?
mikenorman
Post by mikenorman » Thu Jan 03, 2019 2:50 pm
Yeh I’d take it to somewhere that knows what they’re doing. Best off asking a question on your own post and seeing if there’s anyone local to you who can help you out
As for your wheels and height, I’d do both at the same time personally
stevegray1977
Post by stevegray1977 » Thu Jan 03, 2019 2:53 pm
Good advice - ok mate
KIPPER69
Post by KIPPER69 » Thu Jan 03, 2019 4:51 pm
The British Gas Caddy Maxi work vans have really heavy duty springs fitted as standard. I carry a lot of weight but the wheel gap at the rear never seems to alter much.
As for Larger 18 inch wheels you would normally reduce the tyre section to be close to the original wheel rolling diameter, so the wheel total size should be as near as possible without giving speedometer errors of more than 1 or 2%.
If you go to an 18 inch wheel it should have a 35 or 40 section. Something like 18 x 225 x 40.
I am running this size Audi 18 inch A3 Wheel and it helped bring my speedo to about 1 MPH Fast instead of 3 MPH fast.
Speed checked with Satnav.
I hope this helps.
I have just bought the Stance+ Lowering kit and it will be fitted early next week.
Ex British Gas Blue Caddy Maxi. 2011. 1.6 was 102 now 140 BHP.
Colour Coded bumpers and mirrors.
Going for a lowered look with spring kit and coilovers.
Retrofit cruise control to happen early 2019.
stevegray1977
Post by stevegray1977 » Fri Jan 04, 2019 7:52 pm
Wow - that's brilliant, thanks for all that mate.
That's great, so the stance lowering kit? Is that something you buy online and take to a garage?
If you don't mind me asking, how much did you buy it for and how much will the garage charge you? Is that all I would need bearing in mind it's leaf at the back and coil st the front?
As you can see it's quite high
stevegray1977
JAZ8140
Post by JAZ8140 » Sat Jan 05, 2019 6:52 am
wow that is a hefty gap
Southcoastcaddy
Post by Southcoastcaddy » Sat Jan 05, 2019 10:51 pm
Although ours isn't a work van it's low and we moved house on ours and it was fine..
When I say fine though I mean taking the usual precautions as the front lip (as we have a sportline lip/splitter on ours too) can scrape over some larger holes or dips even when she is totally empty :roll:
