Axle flip kit?
Adamgav5000
Axle flip kit?
Post by Adamgav5000 » Fri Jan 04, 2019 9:48 pm
Hi all,
I am about to fit my axle flip kit but I want to make sure that I’m fully prepared. Are all of the bolts reusable or will they need replacing?
If they do need replacing do you all use VW stretch bolts or just replace for normal bolt so they are reusable in the future?
Liam
Re: Axle flip kit?
Post by Liam » Fri Jan 04, 2019 9:49 pm
you replace almost all the bolts with the ones supplied in the kit
Build thread here
Adamgav5000
Re: Axle flip kit?
Post by Adamgav5000 » Fri Jan 04, 2019 10:35 pm
:lol: massive facepalm moment, it’s been a while since I looked in the box! :roll:
Thanks for the reply!
Liam
Re: Axle flip kit?
Post by Liam » Fri Jan 04, 2019 10:54 pm
no worries
Build thread here
JAZ8140
Re: Axle flip kit?
Post by JAZ8140 » Sat Jan 05, 2019 6:45 am
what kit have you got as I want to do this to mine
Adamgav5000
Re: Axle flip kit?
Post by Adamgav5000 » Sat Jan 05, 2019 10:01 am
I have thethe Stance+ kit.
JAZ8140
Re: Axle flip kit?
Post by JAZ8140 » Sat Jan 05, 2019 10:05 am
cheers mate
Liam
Re: Axle flip kit?
Post by Liam » Sat Jan 05, 2019 10:23 am
buy the best kit you can afford as otherwise you will be buying again a few months down the line
Build thread here
hef355
Re: Axle flip kit?
Post by hef355 » Sat Jan 05, 2019 11:10 am
Agree with Liam here, Darkside kits ate really well engineered in my humble opinion, used Eibach and KW in the past and darkside for me are superior
JAZ8140
Re: Axle flip kit?
Post by JAZ8140 » Sat Jan 05, 2019 11:12 am
I don't mind paying good money for quality but cheap by twice , do you have a link to the darkside one please sorry to be a pain
hef355
Re: Axle flip kit?
Post by hef355 » Sat Jan 05, 2019 11:19 am
JAZ8140 wrote:I don't mind paying good money for quality but cheap by twice Image, do you have a link to the darkside one please sorry to be a pain
No trouble at all here you go, I would go gor the super low option as it has an off set locator which is off centre. This will ensure the rear wheel always remains central in the arch. Message me direct if you want my number, happy to help fellaImage
https://www.darksidedevelopments.co.uk/ ... sters.html
sheepy92
Re: Axle flip kit?
Post by sheepy92 » Sat Jan 05, 2019 3:58 pm
Liam wrote:buy the best kit you can afford as otherwise you will be buying again a few months down the line
what is the best kit bud regards
hef355
Re: Axle flip kit?
Post by hef355 » Sat Jan 05, 2019 4:48 pm
For the sane ish kind of money, I wouldnt go VMAXX personally as i inow a few friends who have had issues. I run KW front and darkside super low rear with shortened gaz shocks. I run 20” and use it daily and its brilliant! KW are big money but ive also used STX that are made by KW and are brilliant for front! You could sell the lowering kit and dampers and then buy a darkside kit and Gaz which in my opinion would be a great set up for not massive money
JAZ8140
Re: Axle flip kit?
Post by JAZ8140 » Sat Jan 05, 2019 5:38 pm
cheers buddy i can't pm yet so as soon as they grant me access to the over 30 posts section I will mate
widget2k13
Re: Axle flip kit?
Post by widget2k13 » Sat Jan 05, 2019 10:27 pm
do you have to change rear shocks when you flip the axle ?
