Vcds/ scanner suggestion
nodeward
Post by nodeward » Tue Jan 08, 2019 10:01 pm
I have got a cheap scanner but it only does the engine on my 2011. Can anyone recommend something that doesn't cost the earth so I can read codes on other systems not bothered about messing around with too much just want the fault codes
Sent from my SM-J530F using Tapatalk
mark1a
Re: Vcds/ scanner suggestion
Post by mark1a » Tue Jan 08, 2019 10:37 pm
Have a look at the Carista app & dongle. Reads & resets fault codes plus a few customisation options too.
https://caristaapp.com
2017 Blackberry Maxi Life 150TDI OEM+
Brescia Clubsport 18” | OE Xenons | Limo tints | Vanstyle side bars | Climair wind deflectors
H&R / Darkside lowering | TRC front splitter
Android HU | 4G WiFi | Wireless phone charge
nodeward
Post by nodeward » Wed Jan 09, 2019 7:11 am
Nice, I'll check that out, cheers
Yeti
Post by Yeti » Wed Jan 09, 2019 12:35 pm
Carista's alright, I keep one of the dongles in each of my modern VAG's as part of my breakdown kit. Just make sure you've got one that works reliably on that car, as they can be a bit hit and miss (my Ibiza doesn't seem to like any of them).
I'm going to say something a bit controversial here, I use a copy of a VCDS lead and an older version of VCDS or VCDS-lite ($99 from Ross-Tech), depending what I'm doing. Yep, I'm sure someone, somewhere on the internet has had a car lose all it's settings/burst into flames/eat the driver/go on a chainsaw massacre as a result of using this setup, but I've never had a problem, nor do I know anyone in person who has.
The older setup will do all the Caddy's up to (but not including) the latest shape. Spend about £50 on the cable from someone who's in the UK (not just using a UK address as a front) and you should be ok. Spend £3 on one straight from China and you probably won't be.
VCDS-Lite info page on Ross-Tech - http://www.ross-tech.com/vcds-lite/index.php
If you can accept the limitations of what it can do, the main problem with VCDS Lite is you only get to install and activate it twice. So I'd say use it on a laptop that you know's reliable, even if it is 15 years old, and image the hard disk as soon as you've installed, so you don't need to activate again if you restore the laptop from that image.
Sorry chaps, much as our 2k looks nice, I prefer my Mk2. ;)
nodeward
Post by nodeward » Wed Jan 09, 2019 5:49 pm
Mine is canbus so I dont think the lite version will work for me but I'll check it out
