Help with MFSW
r1lea
Help with MFSW
Post by r1lea » Wed Jan 09, 2019 2:30 pm
Fitted mk6 golf MFSW Image
Upgraded the slipring from
5K0 953 569 BE “mid”
to
5K0 953 569 BD “high”
Fitted new stalks with cruise
5K0 953 502 M / 5K0 953 521 BN
no functions at all working
and getting an error saying cruise short to ground
Anyone help ?
claudiu2s
Re: Help with MFSW
Post by claudiu2s » Wed Jan 09, 2019 2:36 pm
Have u coded the steering wheel accordingly and engine for cruise?
I have genuine VCDS, VagCAN Pro and ODIS with online server access for any of your programming needs in Hemel Hempstead/Watford area.
vcds.diagnostic@gmail.com
https://www.facebook.com/pg/VCDSDiagnos ... e_internal
http://vcds-diagnostic.simplesite.com/
r1lea
Re: Help with MFSW
Post by r1lea » Wed Jan 09, 2019 3:21 pm
Yep
magna413
Re: Help with MFSW
Post by magna413 » Wed Jan 09, 2019 10:44 pm
BE would be MIDLINE, where BD is highline.
And I wanna know how You coded midline to support MFSW?
Le VW Freaks - Our Hobby for VW Cars.
r1lea
Help with MFSW
Post by r1lea » Wed Jan 09, 2019 11:02 pm
I didn’t code a midline
I Upgraded for midline “BE” to highline “BD”
But still have no functions
magna413
Re: Help with MFSW
Post by magna413 » Thu Jan 10, 2019 12:01 pm
Can you post autoscan or somesort of info wirh coding?
r1lea
Help with MFSW
Post by r1lea » Thu Jan 10, 2019 2:36 pm
Here’s my long coding for
16 steering wheel
But is displayed as 8X0 953 521 AF
this is the actual slip ring Image
Also shows this error when I code it for cruise Image
In 01 engine after coding for cruise I get these
claudiu2s
Re: Help with MFSW
Post by claudiu2s » Thu Jan 10, 2019 2:55 pm
That is a Audi slip ring. I have use an audi one as well see the attached picture for coding might help u
E-Bagge
Re: Help with MFSW
Post by E-Bagge » Thu Jan 10, 2019 5:10 pm
It's not a pirate copy of vcds?
r1lea
Re: Help with MFSW
Post by r1lea » Thu Jan 10, 2019 8:54 pm
No it’s a genuine vcds
magna413
Re: Help with MFSW
Post by magna413 » Thu Jan 10, 2019 9:07 pm
Obviously wrong coding.
Try this one: 1082140000
r1lea
Re: Help with MFSW
Post by r1lea » Fri Jan 11, 2019 1:46 am
Thanks mate, that worked
What I don’t understand is why I can’t see the bits in each byte I coded
magna413
Re: Help with MFSW
Post by magna413 » Fri Jan 11, 2019 1:05 pm
Because You're using Audi slipring which loads different label file. Audis have had always 3rd stalk cruise and little bit different MFSW.
