Inspection in 8 days on cluster
Caddy bridge
Post by Caddy bridge » Thu Jan 10, 2019 7:14 pm
As above,what does a inspection constitute of ?
As normally service due means oil filters etc I presume..
dipstr
Re: Inspection in 8 days on cluster
Post by dipstr » Fri Jan 11, 2019 9:01 pm
Means the inspection service is due. They have two types of service indicators
1. Oil change service
2. Inspection service
It all depends on what they have been set to and the type of service that has been done for each one previously.
Caddy bridge
Post by Caddy bridge » Sat Jan 12, 2019 8:49 am
Hi it will will be it’s first inspection I would of thought as its only done 4,000 miles
Caddy bridge
Post by Caddy bridge » Sun Jan 13, 2019 8:08 pm
So...I will do the engine service and check everything on the ramp on the underside then reset it.
Caddy bridge
Post by Caddy bridge » Wed Jan 23, 2019 7:13 am
Ended up doing a inspection with oil & filter change as per service book.
dipstr
Post by dipstr » Wed Jan 23, 2019 7:49 am
How old is the van? 4k is very low for service. If van is new then would suggest that not been set right at dealers. Either way it is done now. Did you reset both service indicators?
Caddy bridge
Post by Caddy bridge » Wed Jan 23, 2019 7:56 pm
I just set the inspection now ! Indicator
It’s a 2017.
dipstr
Post by dipstr » Wed Jan 23, 2019 8:12 pm
Seems the dealer has not set it right at pdi
dipstr
Post by dipstr » Wed Jan 23, 2019 8:14 pm
Oh hang on maybe not lol as date only just registered in my brain . Could be right then depending on when pdi was done
