i have a scirroco flat bottom steering wheel installed and was wondering what is needed to make the sound buttons work and illumination on steering wheel
mfsw slip ring for button illumination/controls
- sheepy92
Re: mfsw slip ring for button illumination/controls
You will need a mfsw airbag harness, a control module and some coding.
- sheepy92
hi doc would this be something you could help me out with as i have not a clue on the coding side if i was to source correct parts would you be willing to help cheers
I'm always willing to help.
The information on which parts you need is already discussed multiple times in the "electrical and lighting" section of the forum. You will also find info on coding in the relevant topics.
