Horn not working...mot looming!!
subdub
Post by subdub » Fri Jan 11, 2019 2:45 pm
Hi guys, since fitting my mfsw i have lost the horn....oooer misses. I have done a bit of reading...do i need to modify the loom at all? Its a 2014 it had no mfsw before. Everthing works apart from the horn. Thanks for any help.
Sent from my SM-N950F using Tapatalk
claudiu2s
Re: Horn not working...mot looming!!
Post by claudiu2s » Fri Jan 11, 2019 3:05 pm
Take the airbag off again and check all wires are connected on the back of it
I have genuine VCDS, VagCAN Pro and ODIS with online server access for any of your programming needs in Hemel Hempstead/Watford area.
vcds.diagnostic@gmail.com
https://www.facebook.com/pg/VCDSDiagnos ... e_internal
http://vcds-diagnostic.simplesite.com/
Beaker2135
Post by Beaker2135 » Fri Jan 11, 2019 4:04 pm
I needed a new air bag loom to get the horn working when I did MFSW on my 2014
subdub
Post by subdub » Fri Jan 11, 2019 6:49 pm
https://www.briskoda.net/forums/topic/4 ... ing-wheel/
I think the bottom photo will solve it. Fingers crossed
Avalanche
Post by Avalanche » Sat Jan 12, 2019 8:50 am
When I fitted my mfsw the horn didn’t work on my van either, but it was fine once it was all coded in by Doc.
2011 Silver 1.6tdi Maxi Panel Van
