Help with Golf R seats on caddy bases!
Hi all,
I have done a search and have seen that many of you have had success in fitting your golf R seats onto the caddy bases and only having to drill 2 holes.
I can not see any 2 holes that line up. I measured the gold seats holes at 480mm wide and the bases at 460mm.
Which of the original holes did you use?
Also I have cut the locating tab off the underside. Do you cut the front one off aswell?
Thanks!
Thanks!
- Rigpig
Re: Help with Golf R seats on caddy bases!
Hi,
I fitted mine with touran bases, straight fit, no drilling required,
If I remember you just need the different size bolts for the seats compared to the caddy ones
- Caddyluv
Yeah your have to cut off the tap and drill holes. It’s really fiddly. If you can get cheap Touran bases. Sooooooooo much easier.
Thanks for your reply’s!
I quite like the lower position so preferably want to use the caddy bases. Last resort will be the touran base.
I will have to try and get a longer spline bit so I can get the bases out and mark them up properly. I only have a short bit that isn’t long enough to get through the hole in the base
- Caddyluv
There is no difference in the seating position I’m very sure.
- Barbel330
Pretty sure there is as the touran bases are higher. That's why I used my caddy bases.
Instagram: @y_5cuf
- Caddyluv
I’m sure there is a thread somewhere that they tried both with R seats and there was like half a cm difference so yeah there higher.
- Caddyluv
Happy to be wrong.
- tommyzooom
The rails can spread, when the seats are sat on when uninstalled ( when on someones garage floor for example)
But they should easily be squeezed back to the required width.
- dan@biali
Touran bases are definitely taller by about 40mm I think. Might even be a bit more than that. I added mine back in as my seats were too low on the caddy bases.
Here is a side by side comparison of the two frames.
Sorry for digging up a ten year old post.
- Barbel330
I much prefer the lower seating position created by my Golf Mk7 GTi seats (same as golf R) being lower profile than the big caddy armchairs. I've said it before but you feel more like you're sitting in it, rather than sitting on it.
Take the frames out, sit your seats on them, line up as many holes as you can then drill new holes for the others. They have pump up height adjustment so even if it feels too low for you, you can just raise them up.
Instagram: @y_5cuf
Really appreciate the help! I will try to tackle this today after a, fingers crossed, successfully attempt at the axle flip
- JD2k
There's not much height difference between the standard Caddy Seats on Caddy bases vs Golf R seats on Touran Bases.
But yes Golf R seats on Caddy bases would be lower than Golf R seats on Touran Bases.
- chadpowell
Hi Tommy, wondered if you could help me out... I had my caddy in the garage yesterday to get Golf R seats put onto my Caddy bases with the addition of some holes drilled in etc, the mechanic said the width is different and won't bolt on and also allow the seat to slide back and forth and has had to order a part in... any idea of this is correct? I was under the impression they bolt straight on once the holes are drilled. Really appreciate any help you can give me.tommyzooom wrote: ↑Sat Jan 12, 2019 10:31 pm The rails can spread, when the seats are sat on when uninstalled ( when on someones garage floor for example)
2016 Caddy Bluemotion 2.0 170hp • Chd2k on Instagram
