Changing bluetooth audio tracks via buttons
- Boonalon
Hi, I have 2014 Highline with a RCD310 and factory bluetooth, I have an iPhone connected. The audio with play no issue at all, but I can't skip tracks via the radio or the steering. the only way I can skip is on the phone itself. is there any add ons or upgrades I can do to get this function to work?
Re: Changing bluetooth audio tracks via buttons
This is likely a software problem between the phone and the Bluetooth module.
Was the van supplied with the RCD310 from factory?
- Boonalon
well, yes all is factory
Ok, in that case it won't be what I thought might be possible if it was a older RNS310 unit.
Get the software levels checked and updates applied if there are any available, that should sort it out.
