oil drip
caddymaxi.
oil drip
Post by caddymaxi. »
Hi All,
I'm trying to fix any oil leaks/drips coming from my caddy. I need some help trying to located what the problem is. I jacked up the car and have taken some pictures. The back of the engine seems to have fare bit of oil along it.
It's not coming from the
-drive shaft
- oil sump
- cam cover seems ok, all bolts re torqued
It could be
It seem to be coming from the top left red pipe, i believe thats connected to the turbo? possible seal gone?
Does this leak seem like a common issue?
dipstr
Re: oil drip
Post by dipstr »
Most likely to turbo intake pies
caddymaxi.
Re: oil drip
Thaaks for the reply. Is that normally an easy fix?
shanky887614
Re: oil drip
Post by shanky887614 »
if i was you id run my finger along the rockercover and check for oil (where the plastic along the back right touches the cylinder head)
its a common spot for them to leak
or from the tandum pump in the same location
