Engine cover
Posted: Tue Jan 29, 2019 7:32 pm
by Dog walker
Hi I've got a MK4 66plt 2.0 hdi and would love a cover for it
Not the same as Markels blackberry life I know I've got one part no 04l 105 925Q it's not even the same engine and mines a 150 aswell
Help please Gary
Re: Engine cover
Posted: Sat Feb 02, 2019 8:54 pm
by Dog walker
Hi all still looking for correct part no for my none bluemotion caddy maxi 2.0 hdi 150 somebody must know VW were no help at all ,I've got numbers for bonnet insulation and underbelly tray here's hoping cheers
Re: Engine cover
Posted: Sun Feb 03, 2019 7:17 pm
by mark1a
Hi, guess it's my van you're talking about with that part number...
Do you have the service book? If so, look inside the front cover, and next to item 3, your engine code is printed. For example, I've attached mine and you can see that in my 2017 150TDI Maxi Life, I have a "DFSB". Once you have your engine code, you could cross reference which other VAG vehicles have that same one, and then go looking for a suitable engine cover.
Good luck!!
Re: Engine cover
Posted: Sun Feb 03, 2019 10:20 pm
by Dog walker
Yes I thought mine being the same year power would be the same but alas not any where near only when I had a good look at your engine and mine then someone else is realised the difference was the add blue or bluemotion model that mine is not we live and learn eh
Re: Engine cover
Posted: Sun Feb 03, 2019 10:23 pm
by Dog walker
My engine code is CFHC
Re: Engine cover
Posted: Sun Feb 03, 2019 10:27 pm
by mark1a
Mine isn’t Bluemotion but does require AdBlue as per EU6 - at least if you have the engine code you could find a part number hopefully.
Re: Engine cover
Posted: Sun Feb 03, 2019 10:34 pm
by Dog walker
Have tried VW he just says non listed for my van thanks anyway
Re: Engine cover
Posted: Sun Feb 03, 2019 10:40 pm
by mark1a
No problem. VW and/or TPS will say that of course because that part is not available on a Caddy - computer says no... I got mine on eBay, it came from a Golf mk7 in a breakers yard in mint condition. So once you’ve found a VAG car with that engine code, grab the part number and look on eBay or order it new.
As I said, good luck with this and although it serves no practical purpose, it really tidies up the engine bay and for that reason worth having IMO...
Re: Engine cover
Posted: Sun Feb 03, 2019 10:41 pm
by mark1a
Hopefully someone on here with that engine code will help??
Re: Engine cover
Posted: Sun Feb 03, 2019 10:50 pm
by Bionicman
The engine/manifold cover part number you want for the CFHC engine is 03L 103 925R and you will also require 2 x 03L 103 164 ball head mounting posts (The back two engine/manifold cover ball head mounting posts should be already present on the vehicle) and also/maybe 1 x O3L 133 287 o-ring but not really necessary, well I did not bother anyway as its only the oil filler neck rubber seal between the filler neck and the engine cover.
Re: Engine cover
Posted: Mon Feb 04, 2019 8:51 am
by mark1a
^^ thanks - hopefully OP will be able to get it sorted now
Re: Engine cover
Posted: Mon Feb 04, 2019 4:29 pm
by Dog walker
Yes thanks everyone for your help just got to find one now
