Gas van build
Tommyd1992
Gas van build
Post by Tommyd1992 » Sat Feb 02, 2019 1:45 pm
Got myself an ex BG gas van last summer and after reading so many build threads I thought I’d start my own. It may not be as fast paced as some of the others! This was the van when I purchased her. Image
Tommyd1992
Re: Gas van build
Post by Tommyd1992 » Sat Feb 02, 2019 3:01 pm
Started off by adding the sun strip Image
Tommyd1992
Re: Gas van build
Post by Tommyd1992 » Sat Feb 02, 2019 3:04 pm
Also replaced the radio with the rcd330. Was really unsure of this radio as it was so cheap but after reading as many posts on the forum as I could find I decided to go for it. Image
When removing the parrot kit that was installed by the previous owner I found this glorious hole in my dash.
Tommyd1992
Re: Gas van build
Post by Tommyd1992 » Sat Feb 02, 2019 3:09 pm
Next up was pressed number plates. Thought these made a huge difference Image
Tommyd1992
Re: Gas van build
Post by Tommyd1992 » Sat Feb 02, 2019 3:15 pm
Treated myself at Christmas to a set of 18’s
Tommyd1992
Re: Gas van build
Post by Tommyd1992 » Sat Feb 02, 2019 3:19 pm
A week later I took her in for lowering with H&R front spring and darkside rear kit. Sits much better.
The next day I took her in for a remap which I was told took her up to 152BHP which I can fully believe. The difference is brilliant... the fuel consumption is not. Haven’t decided if it’s the map itself or if it’s me being a lot more throttle happy now that it responds.
Sean1066
Re: Gas van build
Post by Sean1066 » Sat Feb 02, 2019 5:55 pm
That’s just how mine looked when I picked mine up 15 months ago.
I’ve had fun doing mods to and still not finished 😂
Remapped to 140, mk5 golf mfsw, Colour coded bumpers, VW Cadiz 18s, wheels, Vanstyle bumper protecter, Vanstyle rear spoiler, Vanstyle roof rails, After market fog lights. Lowered on V-Maxx, Audi A3 S Line seats on Touran bases, Audi TT air vents
viewtopic.php?f=13&t=36851
Tommyd1992
Re: Gas van build
Post by Tommyd1992 » Sat Feb 02, 2019 6:38 pm
Sean I have followed your build for some time. It looks great. You are a few steps ahead of me with your build. I have done a bit to my van and will update this thread as I can.... a bit new to this still
Tommyd1992
Re: Gas van build
Post by Tommyd1992 » Sat Feb 02, 2019 6:44 pm
Forgot to mention the heko wind deflectors.
Sean1066
Re: Gas van build
Post by Sean1066 » Sat Feb 02, 2019 6:50 pm
Thanks Tommy.
Yours is looking a good build
Tommyd1992
Re: Gas van build
Post by Tommyd1992 » Mon Feb 04, 2019 5:03 pm
Finally fixed the largest cup holders ever installed with a brilliant 3D printed insert.
May have to colour match it in time
Tommyd1992
Re: Gas van build
Post by Tommyd1992 » Mon Feb 04, 2019 5:05 pm
Also fitted my led DRL’s and fitted a HID kit.
The blue headlight is a lot more white in person
Tommyd1992
Re: Gas van build
Post by Tommyd1992 » Mon Feb 04, 2019 5:11 pm
Upgraded the indicator repeaters with these LED’s. Had to fit resistors to stop the fast flash bulb warning when indicating.
Tommyd1992
Re: Gas van build
Post by Tommyd1992 » Mon Feb 04, 2019 5:14 pm
Upgraded the interior light unit to a Passat unit and fitted blue LED’s
Tommyd1992
Re: Gas van build
Post by Tommyd1992 » Mon Feb 04, 2019 5:21 pm
Last of the goodies from the weekend was the auto headlight switch. It flashes the headlights four times when I turn ignition on and then works flawlessly on auto but does not flash if I just leave it set to the headlight position. Not sure I have the right switch.
