Gas van build
Grifnut
Re: Gas van build
Post by Grifnut »
Great thanks 👍
Tommyd1992
Re: Gas van build
Post by Tommyd1992 »
Fitted the sunglasses holder and the rear spoiler.. along with a couple of R badges for more horsepower
Re: Gas van build
Who needs a big turbo when you have an R badge?
Van is looking great mate. Where did you get your sunstrip?
Sean1066
Re: Gas van build
Post by Sean1066 »
You are doing an awesome job on this build Tommy.
Caddy maxi 3.2 VR6 EX BG
My build thread
Tommyd1992
Re: Gas van build
Cheers guys
The sunstrip was just a cheap eBay special. It was about a fiver.
chadpowell
Re: Gas van build
Post by chadpowell »
Tommyd1992 wrote: Sat Feb 02, 2019 3:01 pm Started off by adding the sun strip Image
How is the sun strip holding up? Been advised by my local wrapper that an outside sunstrip is 'better' as it's easier to do.. although I'm wary of how it'll hold up.
2016 Caddy Bluemotion 2.0 170hp • Chd2k on Instagram
Vwjack88
Re: Gas van build
Post by Vwjack88 »
Tommyd1992 wrote: Sat Feb 02, 2019 3:04 pm Also replaced the radio with the rcd330. Was really unsure of this radio as it was so cheap but after reading as many posts on the forum as I could find I decided to go for it. Image
When removing the parrot kit that was installed by the previous owner I found this glorious hole in my dash.
Is this dab mate? Looks good, how much you give for it if you dont mind me asking
Re: Gas van build
Where did you get the sunglasses holder mate?
Tommyd1992
Re: Gas van build
The sun strip needs replacing once a year ish. Could probably keep it on longer but the corners come up after many blasts with the pressure washer. It was less than a tenner and it bugs me when it happens so why not. If you wash it by hand or more carefully it will probably eliminate the corners peeling but I’m too lazy and let the local car wash blokes do it.
The radio was eBay and no it’s not dab but it is CarPlay so I just downloaded a radio app and it works through the radio. Works as factory too with the steering controls. Just plug and play. Was £160 and it’s worked flawlessly.
Sunglasses holder was again eBay. Looks good but complete waste of time and money. Does not shut once you put sunglasses inside them.
Tommyd1992
Re: Gas van build
While I’m here I may as well post a more recent picture.
Before and after the mirror change and steering wheel change. Image
Vwjack88
Re: Gas van build
Post by Vwjack88 »
I'm looking at that wheel myself withe cruise stalks. Did you need anything else? Also did you code it to get it buttons working? Cheers fo reply on radio too 👍
Re: Gas van build
Cheers for that. I’ll give it a miss then
Tommyd1992
Re: Gas van build
Yeah you need the module to go with it. It was a bit of a minefield that I couldn’t get my head around. I was lucky enough to buy a complete set of wheel, stalks and module together from sean1066 a while ago. Then had to get them all coded
JusrajC
Re: Gas van build
Post by JusrajC »
I love the build it looks amazing compared to my one stock on. But the first thing I did to mine was the rcd330 with CarPlay it’s so handy.
rhys.carp
Re: Gas van build
Post by rhys.carp »
Nice build mate!
