Hi Guys,
Looking at switching out my seats, I've got a '10 plate Caddy Maxi which has allready had the conversion so I've got a bench fitted in the back. I've been looking at Audi, Passatt, Golf seats for the front in line with what I've seen from numerous forum members. Will hopefully get a loom sorted and get the heating etc etc.
Anyway enough about the fronts, my question is regarding the rears. There are loads of full sets on ebay: fronts, rears, door cards (like this: https://www.ebay.co.uk/itm/GENUINE-VW-G ... 1438.l2649). Does anyone know if it's possible to bolt these rears in?
If not i suppose I'll go with some Touran rears and then whatever fronts i can pick up separately.
Cheers!
Rear seat question
Re: Rear seat question
Hi
I fitted the removable third row from a Maxi a few years ago and was quite straightforward. They came with the mounting plates (with mushroom pegs) and a set of belts so are easy to remove and are high enough that you don't need to cut the floor to access the foot wells behind the front seats.
