White cluster upgrade
ferda5
Re: White cluster upgrade
Post by ferda5 » Sat Feb 09, 2019 8:24 pm
The white mk60 devices will go to ABS number 1K0907379Q ... but will write a J500 control error but everything works correctly
karlos0891 wrote:
Sat Feb 09, 2019 5:08 pm
does anyone know what is needed to fit white clocks to a touran with the mk60 abs pump?
ferda5
Post by ferda5 » Sat Feb 09, 2019 8:25 pm
I have an electrical scheme from mk60 to mk70 and mk60ec1
karlos0891
Post by karlos0891 » Sat Feb 09, 2019 8:28 pm
so if i get one with same part number but a q instead of a k i wont need wiring changes but can then use a white cluster and it would work with my rns510 aswell?
ferda5
Post by ferda5 » Sat Feb 09, 2019 8:58 pm
1K0907379Q is mk60 and works on white devices ... does not need to change the wiring ... Everything is working correctly, just pis a steering error J500 ... Has no influence ... on VW Touran ... rns510 i did not try
