Tips for removing shocker from hub socket
sheepy92
Post by sheepy92 » Sat Feb 09, 2019 3:58 pm
Has anyone got any tips for removing the shock absorber from hub as they seem to have seized in
Crazy7ony
Re: Tips for removing shocker from hub socket
Post by Crazy7ony » Sat Feb 09, 2019 4:07 pm
Wd40 and also a special tool bit that sits in the cut out behind the hub where the shock slots into.
Insert the bit and turn 90 degrees then the hub/shock should pull out nice and easy.
karlos0891
Post by karlos0891 » Sat Feb 09, 2019 5:08 pm
get some passat alloy hubs for the new shocks. but wd40 and using something in the slot to pry it open should work to get it out
sheepy92
Post by sheepy92 » Sat Feb 09, 2019 6:15 pm
Cheers for the advice guys ive found a right angled pry bar tapped in the slot does the job
Yeti
Post by Yeti » Sun Feb 10, 2019 8:53 am
Just be careful with hammers, chisels, crowbars, etc, as it is possible to break the casting if you give it too much
Sorry chaps, much as our 2k looks nice, I prefer my Mk2. ;)
sheepy92
Post by sheepy92 » Sun Feb 10, 2019 2:05 pm
Yeti wrote:Just be careful with hammers, chisels, crowbars, etc, as it is possible to break the casting if you give it too much
Good point mate i found using a block of wood between the hammer and hub to take away shock
