Tips for removing shocker from hub socket
Posted: Sat Feb 09, 2019 3:58 pm
by sheepy92
Has anyone got any tips for removing the shock absorber from hub as they seem to have seized in
Re: Tips for removing shocker from hub socket
Posted: Sat Feb 09, 2019 4:07 pm
by Crazy7ony
Wd40 and also a special tool bit that sits in the cut out behind the hub where the shock slots into.
Insert the bit and turn 90 degrees then the hub/shock should pull out nice and easy.
Posted: Sat Feb 09, 2019 5:08 pm
by karlos0891
get some passat alloy hubs for the new shocks. but wd40 and using something in the slot to pry it open should work to get it out
Posted: Sat Feb 09, 2019 6:15 pm
by sheepy92
Cheers for the advice guys
ive found a right angled pry bar tapped in the slot does the job
Posted: Sun Feb 10, 2019 8:53 am
by Yeti
Just be careful with hammers, chisels, crowbars, etc, as it is possible to break the casting if you give it too much
Posted: Sun Feb 10, 2019 2:05 pm
by sheepy92
Yeti wrote:Just be careful with hammers, chisels, crowbars, etc, as it is possible to break the casting if you give it too much
Good point mate i found using a block of wood between the hammer and hub to take away shock
