In Cab DAB/Double Din Entertainment
RyyJones
Re: In Cab DAB/Double Din Entertainment
Post by RyyJones » Fri Mar 01, 2019 7:31 am
Ahhh right makes sense! Sure il find somewhere to splice into cheers
W11JKK
Post by W11JKK » Sun Mar 03, 2019 11:44 am
Can anyone reccomend any Apple car play stereo's?
Taz6584
Post by Taz6584 » Sun Mar 03, 2019 12:20 pm
Another vote for Xtrons here, I've included a link below to the one I've got. It does look a bit too new for the dashboard (I have a 2011 caddy 2K) being all screen and no buttons but I love the big screen. Great for watching movies/shows and general use.
The only way I can describe it is like having a android tablet in your dash, it's fantastic. I connect to my phone's hotspot and away I go. Music/internet/films/shows/navigation/dab radio it does it all. If you don't want to use your phone data you can add a WiFi dongle that accepts a sim card for a fully mobile WiFi hub.
Worth mentioning some people have incurred battery drainage when these units are not wired in correctly but mine has been perfect. When fitting to a vehicle with can bus just make sure the red wire labelled Acc is cut or disconnected.
Once fitted the system needed some setting up to show the correct door was open (was initially switched ie showing passenger door was open when drivers was) but I learned more about the system and how to use it better.
Maybe I'm biased because I'm an android fan but I'm so impressed with it. Haven't seen anything that comes close from the bigger car audio manufacturers (pioneer, alpine etc)
http://xtrons.co.uk/pe98mtvpl-android-8 ... skoda.html
Craig Cheatham
Post by Craig Cheatham » Sun Mar 03, 2019 3:37 pm
Hi Taz,I have exactly the same problem with my Android head unit as regards the doors showing open the wrong way round. How did you cure it please?
Taz6584
Post by Taz6584 » Sun Mar 03, 2019 4:07 pm
Hi Craig first go into settings, car, factory settings (you will need a code here, mine is 126 but can vary. I found this out by googling it and found a few other codes which might work. Alternatively contact Xtrons or the manufacturer). From there go to CanBus then front door. Click on the drop down and select switch.
That's it your done, hope that helps.
Gary.8
Post by Gary.8 » Sun Mar 03, 2019 6:05 pm
Another vote for Xtrons...
can't fault it
Craig Cheatham
Post by Craig Cheatham » Sun Mar 03, 2019 8:23 pm
Thanks Taz, worked a treat, after 12 months of being annoyed i'm like a dog with two dicks! :D thanks mate
Taz6584
Post by Taz6584 » Tue Mar 05, 2019 12:42 pm
Happy to help
Dugpal
Post by Dugpal » Thu Mar 07, 2019 6:58 pm
Those with Xtrons units,
Has anyone found a microphone, or location, to put one that people can actually hear you without too much background noise at their end?
I used the one it came with for a bit mounted on my steering column, I had to lean forward like I had my chin on the steering wheel like a granny would so people could hear me!
I then got another one off ebay and mounted it at the top of the driver door in the trim, people can hear me if the van is stopped, but if I'm on the motorway I have resorted to using the headphone cable my phone came with! I's like it so I don't have to use headphones to be heard.
2011 1.6 TDI, remapped, Merc seats, HID's foglights and autolights retrofit, lowered, 17s, cruise & trip computer switch retro fit, bike rack, xtron radio, retro fitted Touran electric windows, rail cover
Taz6584
Post by Taz6584 » Fri Mar 08, 2019 11:19 am
I haven't mounted mine yet as using the front built in mic with decent results.
Was thinking of fitting a golf mk4 dome light which integrates the microphone as well as adds reading lights but thats a mod for a later date.
ellis
Post by ellis » Mon Mar 11, 2019 4:20 pm
Taz. Exactly the information i was looking for, everyone has been a great help thank you. Will check these out :)
