Hi,
I have been attempting to do a rear seat conversion on my 2017 caddy and have run into a bit of trouble finding the part numbers for trims after removing bulkhead and floor panel.
I wish to fill the hole in on the B pillar where the bulkhead was removed and also i have a passenger side sliding door and require a Plastic trim to replace the original step trim and need plastic trim for drivers side also.
If someone could point me in the right direction regarding part numbers or sourcing them it would be much appreciated.
Rear Seat Conversion Including All Trims
Re: Rear Seat Conversion Including All Trims
Hi, welcome to the forum.
The part numbers you are after are on the forum, I haven't looked but the most likely location will be the "Useful Part Numbers" thread in the how-to section. You won't have access to this but you can gain access by following the procedure set out in the thread linked in your registration and activation emails.
