Has anyone with an older Caddy/Touran (Pre 2010) upgraded to the newer style dash Cluster?
Apologies if there is a thread about this already. Restricted access*
Has anyone done a Cluster upgrade??
- LegendaryAllen
We're not here for a Long Time, we're here for a Good Time!
Re: Has anyone done a Cluster upgrade??
Yes it is possible to do the upgrade to newer style instrument clusters.
- LegendaryAllen
Do you know what’s involved?
Is it just plug in or need coding?
U need to make sure your ABS pump will let u upgrade to white cluster. If ABS pump is ok then you need adapter loom, cluster and coding.
I have genuine VCDS, VagCAN Pro, SMOK and ODIS with online server access for any of your programming needs in Hemel Hempstead/Watford area.
vcds.diagnostic@gmail.com
https://www.facebook.com/pg/VCDSDiagnos ... e_internal
http://vcds-diagnostic.simplesite.com/
- LegendaryAllen
If the ABS pump isn’t compatible could it not just be upgraded?
It can be upgraded but this will cost u more
- LegendaryAllen
Do you know the approximate cost with and without ABS pump?
