Bulb failure 2010 1.9tdi
Lewis1983
Re: Bulb failure 2010 1.9tdi
Post by Lewis1983 » Thu Mar 14, 2019 6:57 pm
Might be worth a try 😉
Lewis1983
Post by Lewis1983 » Fri Mar 22, 2019 7:17 pm
Worked a treat with the bulbs suggested :D
mikenorman
Post by mikenorman » Fri Mar 22, 2019 7:19 pm
The ones I mentioned?
Maxedmini
Post by Maxedmini » Fri Mar 22, 2019 8:07 pm
I have not tried on a caddy but most vw can be coded to use led number plate bulbs I believe the option is
License Plate Light w/o Pulse Width Modulation (PWM) [LED Light] and disable Lamp Monitoring (Cold) License Plate Lamps active
Lewis1983
Post by Lewis1983 » Sat Mar 23, 2019 2:28 pm
Yeh they work bang on
mikenorman
Post by mikenorman » Sat Mar 23, 2019 8:30 pm
Lewis1983 wrote:Yeh they work bang on
Nice Image if you need some led side lights? Which I can recommend just holla Image
