Top mount Coilover fixing
MillerTime
Post by MillerTime » Mon Mar 11, 2019 10:41 am
Have been fitting an STX lowering kit over the weekend and would like to know the best socket to enable me to torque up the 22mm recessed nut on the top strut mount which also allows me to hold the shaft with a 10mm socket. Any advice gracefully appreciated.
Giddy
Re: Top mount Coilover fixing
Post by Giddy » Mon Mar 11, 2019 1:41 pm
Try 22mm oxygen sensor socket
My Caddy 4 build thread viewtopic.php?f=13&t=37368
Post by Doc » Mon Mar 11, 2019 2:30 pm
Maybe a hollow socket set like Halfords Vortex will allow you to get another socket on the 10mm.
tommyzooom
Post by tommyzooom » Mon Mar 11, 2019 9:37 pm
I use a cranked 22mm ring spanner
hungry monkey
Post by hungry monkey » Mon Mar 11, 2019 10:38 pm
We got a £5 socket from halfords then used an angle grinder to create two flats on to which an adjustable spanner could grip, when I did my mk1 suspension the other week - the thru sockets didn't go big enough for the top mounts!
