Steering wheel airbag part no, etc
Sunn159ti
Post by Sunn159ti » Mon Mar 11, 2019 7:57 pm
Hi People,
I am considering upgrading to an MFSW steering wheel, part no 5TA419091AD. Can anyone please tell me what part no's I need for this upgrade to my Caddy please;
It's a 2012 1.6 TDi blue motion, with cruise control on the left stalk, MFD on the right. I think I need the following parts to go with, but I'd appreciate it anyone can advise on other parts I'd need too, plus part no's if possible;
Basic stalks to replace existing
Squib ring & controller
Harness
Airbag & cover
Many thanks in advance!
LegendaryAllen
Re: Steering wheel airbag part no, etc
Post by LegendaryAllen » Mon Mar 11, 2019 8:06 pm
I can’t speak to how other ppl have done it but I just took my airbag off and looked if it was single or dual stage (determined by the number of connectors on airbag) I bought a airbag that matched. I got the loom for the airbag then I made a loom out of my existing loom and the new loom. I’m not sure why you would be looking at changing the stalks. Unless u just want to upgrade them to newer versions?
We're not here for a Long Time, we're here for a Good Time!
andyreflexsilver
Post by andyreflexsilver » Mon Mar 11, 2019 8:20 pm
You are right in what you need, it takes a bit of digging and research to find the right part numbers, one thing to bear in mind with that wheel, the cruise control won’t work on the wheel without a special module from a guy on here called Spacewalker
Sunn159ti
Post by Sunn159ti » Mon Mar 11, 2019 8:26 pm
Thanks for the heads-up on single and dual stage, I wasn't aware of that!
I'm ideally looking for a plug & play on the airbag loom...not something I fancy testing until its really needed and then it would most likely be too late to worry about whether wiring mods on the loom had or hadn't worked :mrgreen:
Planning on changing the stalks as the wheel would have cruise and MFD controls, replacing those on the stalks.
Sunn159ti
Post by Sunn159ti » Mon Mar 11, 2019 8:27 pm
OK, special module meaning, not a standard VW part to swap out then? I will try to track down Spacewalker! Ta for the steer!
