19 inch et45 8.5j tyres?
Currently looking for the right tyres to fit without rubbing.
Will be lowered on KW coilivers.
Think I need 235/35 ?
Any help would be great alloys are the phaeton replicas.
- Barbel330
Re: 19 inch et45 8.5j tyres?
You might still get a little rubbing with 235/35 but it depends how much you lower it. 225/35 or even 215/35 might be better if you plan on going low.
I run 235 when I was on coilovers. Slight rubbing on inside rear arch liner and a tiny bit on the actual arch. I still run 235 now but I'm on air which avoids the side to side axle movement that you'll get with leaf spring set up. You'll need to remove the rear arch liners for 235.
Instagram: @y_5cuf
- Damo2k
Also wondering about 18" 8.5j et 29 would these fit caddy or be to wide?
Can cope with a little rubbing. Every now and again.
Tyres currently have 255/35/19 and it rubs alot.
What would the ride quality be like in the 225?
- Barbel330
No real difference to 235 I'd say. Only a slight bit of stretch in comparison, nothing noticeable. Yeah 255 is a bit wide
Instagram: @y_5cuf
- Barbel330
What would you go with?
- Barbel330
I've always used 235/35/19
Have a look for whatever make of tyres you like and see what's cheaper. 225 or 235. I've got michelin pilot sport 4s on mine.
Instagram: @y_5cuf
- Damo2k
Like sliding door problems?Barbel330 wrote:You'll have problems with et29
Can buy nice set of audi alloys not sure wat problems id run into..
- Barbel330
Sliding door definitely, and arches depending on how low it is.
Instagram: @y_5cuf
Thanks for the input will get some 235s ordered up.
- Ash1987
How low would you recommend dropping for a set of 19” then without any disturbance, I tend to not have anything in the back other than my golf clubs
- Barbel330
You can go as low as you like if you have the right offset and tyre.
Instagram: @y_5cuf
- Ash1987
I’m only planning on putting some springs on the front and then on the rear a set of darkside leaf spring kit witch retail at about £160
I’m on 225/40 still get some ride comfort compared to 235/35.
