Sat in my caddy broken down
Re: Sat in my caddy broken down
Glad to hear you got there with it mate. May you have many miles of trouble free motoring in it
Thanks SF
Unfortunately it's just died with a p0087 00 (232)
2011 1.6 102ps ex BG
225/40/18 ps3 Santiago wheels
Oh bloody hell!
I’m gutted for you mate
- Sean1066
Not again?
You are having so much bad luck with your caddy.
What wrong with it now
Fuel rail low pressure that feeds injectors?
Anybody got a clean 1.6tdi fuel tank knocking about?
I've got a SWB diesel tank in Tamworth if you can come get it.
Would it fit a maxi?
Nope, the fill neck is different.
Try sirus, they said they isually have these on hand
Was looking at these on ebay. Breaking a 2014 maxi 38000 miles. Buyer to collect tank though from Heathrow. Bit of a drive from Stockport
https://rover.ebay.com/rover/0/0/0?mpre ... 3285276059
https://rover.ebay.com/rover/0/0/0?mpre ... 3285276015
Surely it should be sorted though? Didn't they flush/go through the whole fuel system?
For the kind of money you paid them, I wouldn't be sticking my hand in my pocket for anything else......you went with a problem, they quoted you to fix it, they fixed it, it's still not working?
if anybody can help by what the autoscan reveals
Thursday,18,April,2019,14:39:31:49022
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4437.4
Data version: 20190114 DS296.0
www.Ross-Tech.com
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
VIN: WV1ZZZ2KZCX045908 Mileage: 94950km-58999miles
01-Engine -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
56-Radio -- Status: Malfunction 1010
Address 01: Engine (J623-CAYD) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 TF HW: 03L 907 425 C
Component: R4 1.6l TDI H43 9978
Revision: --H43--- Serial number: 00000000000000
Coding: 00114014032500080000
Shop #: WSC 44060 003 1048576
ASAM Dataset: EV_ECM16TDI02103L906023TF 003002
ROD: EV_ECM16TDI02103L997557M.rod
VCID: 7DA4F15B5D7A990FF5B-8028
1 Fault Found:
10116 - Fuel Rail/System Pressure
P0087 00 [104] - Too Low
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 3
Mileage: 94948 km
Date: 2019.04.18
Time: 12:07:24
Engine speed: 2342.00 /min
Normed load value: 87.1 %
Vehicle speed: 59 km/h
Coolant temperature: 97 °C
Intake air temperature: 24 °C
Ambient air pressure: 1020 mbar
Voltage terminal 30: 14.118 V
Unlearning counter according OBD: 40
Fuel high pressure: actual value-FUP_FIL: 8.136 MPa
Fuel pressure regulator valve: specified value rail pressure-LV_PCV_CTL: 00000000
Fuel level-FTL_CAN: 10 l
Fuel temperature-TFU: 54 °C
Fuel Metering Valve-VCV: 33.897 %
Fuel Pressure Regulator Valve-PCV: 42.415 %
Fuel high pressure commanded value_1-FUP_SP_KPA_ENVD: 147613.525 kPa
Readiness: 0 1 0 0 0
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BH HW: 1K0 907 379 BH
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 633C400D092603FFC61402E49021C081300000
Shop #: WSC 35110 377 00142
VCID: 79ACE54B49D2A52FD93-802C
No fault code found.
Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
Part No SW: 7N0 907 426 AT HW: 7N0 907 426 AT
Component: AC Manuell H19 0304
Revision: 00001015
Coding: 0000004002
Shop #: WSC 35110 790 50316
ASAM Dataset: EV_ACManueBHBVW36X A01010
ROD: EV_ACManueBHBVW36X_VW32.rod
VCID: 06569EB708ACDAD7A41-8052
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 2K5 937 085 HW: 2K5 937 085
Component: BCM PQ35 B+ 011 1044
Revision: BB011001
Coding: 411A581A8025186B08800082900000640301728852028060648000000040
VCID: 72BED26714A4D677989-8026
Subsystem 1 - Part No: 1T2 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer 22081 26 0512
Coding: 009795
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag00U H06 0013
Revision: -------- Serial number: 003HL0079XEI
Coding: 000000000000000000000000000000003055
ASAM Dataset: EV_AirbaVW10BPAVN750 A01026
ROD: EV_AirbaVW10BPAVN750_VW12.rod
VCID: 3534297B25CA814F7DB-8060
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 1K5 953 507 M HW: 5K0 953 549
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90440KHO000L7
Coding: 0080160000
ASAM Dataset: EV_SMLSNGKUDS A05001
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 3B203F4303EE573F8BF-806E
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 2K0 920 965 E HW: 2K0 920 965 E
Component: KOMBI H03 0606
Coding: 480001
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: 313C1D6BD1A2AD6F213-8064
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 H HW: 1K0 907 951
Component: J533 Gateway H42 1620
Revision: H42 Serial number: 280811F1002596
Coding: 357401
VCID: 3534297B254A814F7DB-8060
1 Fault Found:
01304 - Radio
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 18
Reset counter: 236
Mileage: 94915 km
Time Indication: 0
Date: 2013.09.07
Time: 13:58:45
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 0606
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6A8ECA073CF41EB7209-803E
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2110
Coding: 0000560
VCID: 48CA508F4EB80CA716D-801C
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 140 3201
Revision: 00H20000
VCID: 3432147F223098474A5-8060
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0000560
VCID: 47C853B343A603DF1F7-8012
Address 56: Radio
Cannot be reached
End----------(Elapsed Time: 00:43, VBatt start/end: 12.6V/12.6V)-----------
www.Ross-Tech.com
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 94948 km
Date: 2019.04.18
Time: 12:07:24
Revision: 00H31001
Revision: 00001015
Coding: 0000004002
Revision: BB011001
Coding: 009795
Coding: 0080160000
Coding: 480001
Coding: 357401
1 Fault Found:
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 18
Reset counter: 236
Mileage: 94915 km
Time Indication: 0
Date: 2013.09.07
Time: 13:58:45
Coding: 000000
Coding: 0000560
Revision: 00H20000
Coding: 0000560
Address 56: Radio
Cannot be reached
Yeah the garage fucked up. Hoses on fuel filter mixed up. unfiltered to Hpfp destroyed again and new injectors have a 1 cylinder with diesel pissing out exhaust
Got pics too before and after date stamped
Garage broke my diesel pump and injectors with wrong mixed up pipes. Diesel pump and injectors destroyed just fitted a week ago at 2750.
Wrong
https://imgur.com/gallery/Lihpqr5
This was the correct way
Correct vw 1.6tdi fuel hose connections https://imgur.com/gallery/CfAXvTd
Kind motormove man
Kind motormove man https://imgur.com/gallery/vXqMQCW
Wrong
Kind motormove man
Wow, that's one mighty screwup on their behalf.
How they have allowed the van to go out without a full system flush is another questionable move.
They've charged you more for this repair than it'd cost to just swap the entire engine out with a warrantied item. I know the pump is expensive, all the injectors have been tested that is another expensive job but just wow.
You're gonna make their day come Tuesday morning when you hit them with those photos.
Ta doc you are up early! makes me feel better. If the filter had a chance to catch any dandruff it would have been OK. Listen to this after ezee start fireup
Diesel 1.6tdi fuel pump and injectors ruined again due to incorrect fuel filter pipework connections by garage https://imgur.com/gallery/yyLqb52
