Hi all. First off all I'm totally new to the forum so hello .
I will get straight to it. I am currently looking at purchasing a caddy. It is a 56 plate mk 3 caddy. It has the 1.9tdi bls engine in it. The van has done 61k miles and has just had a cambelt and water pump change along with a clutch and flywheel. My question is how reliable are these engines. I have read a few horror stories of them throwing a Conrod through the block etc but are they really that bad? Any replies will be greatly appreciated. Thanks in advance
BLS Engine Code
- Novakid
Re: BLS Engine Code
Welcome.
Regarding the BlS I must have read every topic,web page on this engine as mine as put a bearing out ( not damaged the block).
You will not find much good story's but that's normal as you always get told the bad.
Only big issues I found are that parts are so expensive and sometimes hard to come by.
For example I phoned VW last week regarding a conrod. Guy said only 3 in the country and was about £200 for one rod .
Re: BLS Engine Code
jeeze. I have been scouring the net as well. There's alot of mixed opinions I have found. I had a look on auto trader and have seen one with 178k on the clock. I'm guessing only a small percentage go bang. I love the van but don't really fancy playing Russian roulette with it tbh. Thanks for the reply
Re: BLS Engine Code
Just bought a bls engined 2008 caddy, fingers crossed the rods stay put and don't try going interglacial on me! But I read the AZS engine fits with not too much work and I have one in a golf laying up if someone does go wrong!
Re: BLS Engine Code
In my opinion BLS engines either do 250k without breaking sweat it they go early like mine 113k and that was in a really cared for pampered van. It's luck if the draw.
Re: BLS Engine Code
Fingers crossed here.. Just bought a 2008 maxi on 95k with a bls. Just need to get it safely past 113k then
Sent from my STF-L09 using Tapatalk
