Help with knocking/clunking.
DanHughes
Post by DanHughes » Sun Mar 24, 2019 9:28 am
After some help if possible please if anyone has experienced anything similar. I have had coilovers on the van now for around 3 weeks. I have been experiencing a clunking/knocking from the front that's got worse over the past week. It's one of them annoying knocks/clunks as if something is really loose and it seems to travel through the pedals (can also hear it pretty clearly while driving) but it does not make a noise say at 60 on the motorway although when driving at 30mph on normal roads even with no bumps etc it will still knock. I have had both wheels of the van with a bar in between suspension components and everything seems to be fine. Maybe it will only knock when all the weight of the van is on the floor. I have changed the drop links and also ordered some new top mounts and outer CV joints (one of the CV'S boot had come loose) but it's not making the normal CV joint noise when they go when on full lock turning either way (can a outer CV cause knocking?) never experienced this myself. Really starting to annoy me now as I don't think its the top mounts with it travelling through the pedals etc. Just wondered if anyone has experienced anything similar after fitting coilovers? Thanks in advance.
Damo2k
Re: Help with knocking/clunking.
Post by Damo2k » Sun Mar 24, 2019 9:45 am
How low is your van?could be that your drop links are to long and are hitting your wishbones if van is to low?
DanHughes
Post by DanHughes » Sun Mar 24, 2019 10:52 am
I thought that and checked as best as I can see underneath while the van is on the floor mate seems ok, it's around 40mm drop I'd say, it's hard to explain but it's more of a clunking as if something is really rally loose. Guess I'll just replace the top mounts next weekend and go from there, it's also got worse over the last few days.
Sent from my EML-L09 using Tapatalk
Damo2k
Post by Damo2k » Sun Mar 24, 2019 11:35 am
Have u checked anti roll bar bushes?
Post by Doc » Sun Mar 24, 2019 11:49 am
Does it clunk when you turn the steering wheel side to side? When you go over a bump? When you accelerate or decelerate?
Have you checked nothing has been left loose in the scuttle panel? I found a ratchet spanner in a caddy scuttle panel, the owner had checked all underneath after having his van lowered but couldn't get to the bottom of his knocking noise since having his coilovers fitted.
DanHughes
Post by DanHughes » Sun Mar 24, 2019 1:42 pm
Anti roll bar bushes are fine as from what I can see with a bar in there moving them about, don't look overly worn either to be fair. The best way I can describe is it clunk's when just driving at 30mph over uneven Road, if I hit a pothole it's just hard like when running coilovers but no clunk. It's hard to explain but it's fine with the wheels locked, turning, accelerating and decelerating. I have had the clunk before on a car and changed the drop links and it was all good. Nothing under scuttle I checked yesterday as I had the wiper motor off to check the top mounts.
DanHughes
Post by DanHughes » Sun Mar 24, 2019 4:34 pm
Just found the dogbone mount bush has loads of play, with it being at the gearbox i'm thinking maybe its giving excessive movement in the shafts and causing it to feel like the shafts are knocking, has anyone experienced this before I order a new mount and bush insert? Cheers :D
Damo2k
Post by Damo2k » Sun Mar 24, 2019 4:44 pm
I would leave the van stationary and pull up handbrake put into gear and work the clutch up and down,u should hear or feel if its gone.
DanHughes
Post by DanHughes » Sun Mar 24, 2019 4:51 pm
Yeah good thinking, cheers buddy.
Post by Stedlocks » Fri Jun 07, 2019 11:31 pm
did you get to the bottom of this fella?
