Aftermarket RCD330
Ripley55
Re: Aftermarket RCD330
Post by Ripley55 » Thu May 16, 2019 7:21 am
Many Thanks for that @bob86
That's a blinding selection, Cheers :D
Dave
robblowen
Post by robblowen » Thu May 16, 2019 10:46 am
@Ripley55 cheers for that mate, looks like I'll be purchasing one of those then!
mikenorman
Post by mikenorman » Fri May 17, 2019 9:16 pm
Has anyone got a link for a camera to suit the rcd330? Cheers
Boonalon
Post by Boonalon » Sat May 18, 2019 7:58 pm
Sorry lads been away, the fitting is very straight forward, once you have the input cable for the back of the headunit.
There are a couple of excellent how to’s on here, fitting a camera to a VW/any aftermarket is the same.
For me I used this cheap camera
https://rover.ebay.com/rover/0/0/0?mpre ... 3289484140
I used a feed off the main fuse board for the 12v feed on the input connection at the headunit and ran a wire off the same 12v feed through the van when I was fitting the camera cable. Some others use the wiper motor, either is good.
You need a time delay filter relay like this on the feed from the reverse light feed.
https://rover.ebay.com/rover/0/0/0?mpre ... 3498693309
I used this site a good how to
http://rcd330plus.com/showthread.php?tid=13
Once all is fitted you may need to change some coding with VCDS, the RCD330 will show as a it own unit
Here is my coding
Radio
Part #: 6RD035187B
Coding: 16000440040005 (hex)
Component: Radio
[No fault codes]
To be honest it’s very straight forward, the connections into the reverse light few is probably the worse part. As away read read and double check all
I_am_Diesel
Post by I_am_Diesel » Mon May 20, 2019 10:23 am
Would my rear parking sensor warning thing still work with an aftermarket RCD330 does anybody know?
Boonalon
Post by Boonalon » Mon May 20, 2019 10:27 am
Should not be an issue, mine are factory and still showed on radio until I fitted the camera
I_am_Diesel
Post by I_am_Diesel » Mon May 20, 2019 10:43 am
Thank you Boonalon, much appreciated. :D
Ripley55
Aftermarket RCD330
Post by Ripley55 » Thu May 23, 2019 5:00 pm
Guys
I keep coming back to looking at a reverse camera, and have a couple more questions regarding my RCD330
So, I’ve got the cable
And need advice on how it fits, as I said earlier, this unit was a blinding buy, and was an easy install, so getting it back out to fit the cable should be a doddle, it’s just what do I need to do Image
Secondly I’ve been looking at a wireless system as per the photos attached and wondering if anyone has tried this ? they are under £30 on eBlag ? I’m not lazy but it saves trying to run cables to the head unit ?
Allegedly these are ‘Designed for VW Transporter/Caddy?
What’s your thoughts chaps, Advice ? Pitfalls ?
LS Spark
Post by LS Spark » Thu May 23, 2019 5:15 pm
I ordered this bad boy from the same place yesterday. Fingers and toes crossed it works well.
I am now searching for a wired camera....any suggestions? There is one on eBay for £11!?! Seems tooooo good to me true
Gloss Black Badges, ‘KillAllWipers’ Delete, Van-X tinted HL brake lens, Van-X glove box, Van-X smoked side repeaters
LS Spark
Post by LS Spark » Thu May 23, 2019 5:16 pm
Boonalon
Post by Boonalon » Thu May 23, 2019 5:27 pm
I have the wired version for £10, works grand, the angle is a tad low, but my main reason was to see the tow bar works a treat.
It’s a van so wiring it is not too hard at all
Ripley55
Post by Ripley55 » Thu May 23, 2019 5:36 pm
Hello @Boonalon
Wouldn’t mind a quick line on how to install that cable at the back of the 330, and any tips cheats as it were. As I said I’m not lazy but would really love to try the wireless route.
Dave
Doddman
Post by Doddman » Sat Jun 15, 2019 4:10 pm
Please post back when you know it's good!
Could you send a link somehow?
Im trying to replace a broken 3rd party android screen. I have zero electrical knowlege! Hoping this would just be plug and play?
LS Spark
Post by LS Spark » Sat Jun 15, 2019 11:31 pm
The stereo and camera work well together. I wouldn't say it is plug and play. Takes a bit of work to get it wired right but if you can follow the instructions, its not too bad.
Need to splice into a couple of wires
I used a delay relay as well so the camera stays on for a few seconds after leaving reverse gear
Doddman
Post by Doddman » Sun Jun 16, 2019 6:15 am
How was installing the actual head unit? Simple?
On the verge of buying one of these rcd300 units from eBay.
