Range display
Range display
I seem to have changed the display from range to outside temp but can't seem to get it back. Is there a sequence or something? Clocks only have 2 buttons and just can't get it back for some reason. Tia
Re: Range display
Have seen a retrofit wiperstalk with trip button online would this control it?
Re: Range display
I'm fairly sure when you have no controls the cluster swaps from temp to range automatically when your fuel level drops below a certain amount.
You can retrofit the trip stalk which will allow you to scroll a few more bits of info like distance, trip time, mpg etc. Depending on the build year of your caddy there are different stalks.
Re: Range display
Thanks doc. It's a 2011 ex bg will see what i can find
