Hi,
Does anyone know if roof rails from a 2017 MK4 Maxi Life would fit a 2014(64) MK3 Maxi?
Cheers, Drew.
Roof Rails
Re: Roof Rails
Anyone know the answer on this one as would like to get back to “mark1a” on here regarding this?
Cheers Drew
Cheers Drew
Re: Roof Rails
Bump?! Anyone, any ideas?
Thanks!!
Thanks!!
Re: Roof Rails
i suppose yes, the shell is the same
Re: Roof Rails
Thanks!! Hopefully should be fine then?!
Re: Roof Rails
Yep I can confirm that they are the same part numbers for the roof rails fitted to a 2014 maxi and a 2017 maxi.
Re: Roof Rails
Sweeeeet, thanks fella!!
Re: Roof Rails
Would they fit a 2008? Yes,no, or need work?
