Digital dash display question
Hi all,
Can you upgrade or unlock functions on the digital display on a 2011 1.6Tdi Caddy?
like MPG, range etc? Mine only gives trip mileage, total mileage and km/h at the bottom.
Many thanks,
Leeapole.
Many thanks,
Leeapole.
Re: Digital dash display question
Yes, you can have MPG, distance, average speed, trip time, miles to empty, etc. Just add a means of scrolling the display, either a trip stalk or multi function steering wheel, and some simple programming in the instrument cluster.
- Damo2k
Hi doc,iv fitted cruise control and trip button..
Coaded the cruise and that works 100%
But my trip button doesnt work..
Is it just the case of coading the cluster for it?or will i need the highline clocks for it to work?thanks
If yours is 2011+ then just as above it requires a simple reprogramming of the instrument cluster.
- Damo2k
Yea mines the mk4 2016 do you know what byte i have to change?thanks again
Not off the top of my head but VCDS has it's description as "multi function display active".
- Damo2k
Perfect thanks doc..i will give it a go
Is it possible to have this without upgrading stalks or steering wheel? I.e. can the button on the left do anything different? only seems to show distance until servicing form what i can tell.
Nope, sorry, if that was an option I would have said.
I fitted trip and cruise stalks to my 2011,
The multifunction display to enable mpg/miles to empty etc can be turned on easy with carista.
The cruise needed coding with vcds
That's true.
This guy is asking if he can gain any functionally without adding stalks or MFSW.
So does the cruise control stalk also have the trip computer?? The only one's i can find with cruise don't mention the trip computer.
I never realised it was on the other side..
My build thread.. https://www.caddy2k.com/forum/viewtopic ... 13&t=39551
Does anyone know what I'd need to get this (mpg and cruise control) on a 2009 caddy?
59 white SWB 1.9tdi
Hello All, new to this so please excuse me asking the obvious. Where would I go for digital dash & cruise control stalks? Is this breakers yard or buying from VW or aftermarket or what?
Thank you
Mike
Thank you
Mike
