My caddy 2L has the most random fault. Over the past 10 months it would start every time no problem but on the very odd occasion when u drive off sometimes it would be off a cylinder. It didn’t do this fault for about 6 months! Then at the weekend past it did it two mornings in a row. When it does it I would drive it with hardly touching the throttle for about 1/2 a mile then like someone flicked a switch it would just run perfectly again. No fault codes and no warning lights. It has Bosch 03L 130 277J injectors it has 95k and is in very good condition. Anyone every experienced anything like it?
Thanks Neil
2012 2L CFH caddy maxi life random fault
Re: 2012 2L CFH caddy maxi life random fault
Hi Neil, did you get to bottom of this?
Sent from my SM-J600FN using Tapatalk
