Lowering question
Waltdog
Lowering question
Post by Waltdog » Thu Apr 25, 2019 1:07 pm
How much should I have my caddy lowered on 225/40/18’s? Has anyone got photos of 40mm vs 60mm etc? Thanks in advance
Caddyluv
Re: Lowering question
Post by Caddyluv » Thu Apr 25, 2019 2:19 pm
You can go quite low buddy. Set what you think. Drive round the block so the suspension settles a bit. Check again. It only takes a few mins to raise or lower it if your using a ramp.
Waltdog
Post by Waltdog » Fri Apr 26, 2019 8:17 pm
Thanks for the reply. I’m gunna go with 60mm to start
Skully
Post by Skully » Fri Apr 26, 2019 9:53 pm
My Maxi running 225/40/18 and lowered 60mm in front and 70mm rear (JOM coilover + axle flip kit) :
1996 Mk3 VR6
2017 Caddy Maxi 2.0 TDI
2013 RSV4 track bike
Waltdog
Post by Waltdog » Fri Apr 26, 2019 10:05 pm
Very nice
Pete M
Post by Pete M » Fri Apr 26, 2019 11:38 pm
Would the same be ok on a 2009 model?
threepeaks
Post by threepeaks » Sat Apr 27, 2019 11:02 am
lowered on 60mm H&R springs and axle flip kit. Handles much better especially the wallowing on the motorway in strong winds. £500 all in Total cost. Well Chuffed. Also Running 225/40/18's
Waltdog
Post by Waltdog » Sat Apr 27, 2019 6:02 pm
Looks smart that,I’ll get some photos of mine up once it’s done
RobbieCT
Post by RobbieCT » Mon Jun 10, 2019 7:37 am
Skully wrote:My Maxi running 225/40/18 and lowered 60mm in front and 70mm rear (JOM coilover + axle flip kit) :
sorry for the post hijack. This pic isn't in Skullys build thread. Skully did you have the roof sprayed or is that also vinyl like the side panels I've been thinking of doing the same to mine.
Sent from my EML-L09 using Tapatalk
Skully
Post by Skully » Mon Jun 10, 2019 7:45 pm
I will update my ride thread sometime soon.
It is vinyl.
1996 Mk3 VR6
