Removal off exterior door trim the black part
As above guys any clues on how to remove the black panel on exterior of the door I want to paint it
Re: Removal off exterior door trim the black part
If it is the one on the wing door/tailgate then you have to remove the door panel and plynth is held in with 10mm nuts
If it's the trim piece just behind the front door window, just drop the window fully and pull out the seal. You'll see two screws that hold the trim in place.
Once again doc legend just finding all these little bits out
