Which clocks can you fit in 06 plate caddy
gjseb
Post by gjseb »
As above which clocks would fit in 06 plate caddy
r1lea
Re: Which clocks can you fit in 06 plate caddy
Post by r1lea »
Any as far I’m aware mate, you don’t have component protection to worry about.
I’ve just fitted the latest Scirocco clocks I’m my mk4 Image
Sean1066
Post by Sean1066 »
Hi r1lea
Do them clocks fit straight in to a mk3 facelift?
Caddy maxi 3.2 VR6 EX BG
My build thread
r1lea
Post by r1lea »
Yes, there all the same at the back, you just use your binnacle
The Rocco clocks with Rocco binnacle Image
The Rocco clocks with my caddy binnacle Image
hef355
Post by hef355 »
Yes Sean mate done mine last year, same as Lea’s but the R scirocco version, blue as opposed to red needles ... great clocks and i’m very pleased with them
Sean1066
Post by Sean1066 »
Thanks guys Is there any coding to do ?
My build thread
r1lea
Post by r1lea »
Yes mate it’s not a plug n play thing
You need to get someone with the relevant kit for the immobiliser and mileage transfer as well as vcds for the coding
Depending where you are, doc did mine
They are far from a straight swap into a 06 caddy.
For 2010+ they are fairly straightforward to fit once coded up properly but 2015+ will have problems if there is ACC or factory head unit still fitted.
For the OP, you can fit anything from a red display midline (half height) cluster right up to the latest 3D colour display you see mentioned above into your 06 caddy. There are varying degrees of difficulty and costs.
gjseb
Post by gjseb »
What so theses Rocco clocks will go into 06 plate caddy , what's needed to code them in
ABS upgrade, CAN gateway upgrade, adaptor harness, new key transponders, some coding.
That's all really.
gjseb
Post by gjseb »
Not much then lol right would love them but sounds like it's a bit out off my league for coding
gjseb
Post by gjseb »
Would any one be willing to do it for some beer tokens
Gsi_Jimbo
Post by Gsi_Jimbo »
With the clocks I’m assuming I’ve got to buy diesel ones? Or doesn’t it matter is that a coding issue? Do the mk7 golf ones fit also ?
r1lea
Post by r1lea »
Yes you can use a petrol cluster as the coding will adapt it, but then obviously you’d need to swap the dials over from your caddy clocks which then makes it look exactly the same which is why I got a diesel version to keep the newer look
Adie66
Post by Adie66 »
Just bin looking into changing my clocks in my 2008 maxi
What does it roughly cost for the coding ect
I just want a temperature gauge and mpg so dont want to spend a fortune
