Which clocks can you fit in 06 plate caddy
AdoleFiddler
Re: Which clocks can you fit in 06 plate caddy
Post by AdoleFiddler » Mon Aug 19, 2019 9:52 pm
Would you be able to have the onboard computer working?
Mpg etc...
I have a 58 plate caddy
claudiu2s
Post by claudiu2s » Tue Aug 20, 2019 10:40 am
Mpg etc...
it depends what clocks u have, if midline ones then u will need to add trip stalk and code everything accordingly and u will have that. if lowline then u will need to upgrade your clocks
I have genuine VCDS, VagCAN Pro, SMOK and ODIS with online server access for any of your programming needs in Hemel Hempstead/Watford area.
vcds.diagnostic@gmail.com
https://www.facebook.com/pg/VCDSDiagnos ... e_internal
http://vcds-diagnostic.simplesite.com/
AdoleFiddler
Post by AdoleFiddler » Tue Aug 20, 2019 11:57 am
I’m new to all this. What do you mean by midline and low line ?
ziggmike93
Post by ziggmike93 » Tue Aug 20, 2019 4:12 pm
pre <10 is it just the touran clocks that work? well are the easiest to fit/code? does it matter what touran clocks you pick up other than diesel?
if so what extra functionality do you get from midline to highline or do they display all same info (just smaller screen)
claudiu2s
Post by claudiu2s » Wed Aug 21, 2019 1:12 pm
midline will display range, highline will have van setting to change via MFD, van pictogram plus all what midline does.
