Rear seats install.
Cy Russ
Re: Rear seats install.
Post by Cy Russ » Wed May 08, 2019 5:57 pm
Caddy life is a 5 seater and caddy maxi life is 7 seater if I'm not mistaken so a caddy van can be converted to 5 seater, maybe they don't want to take on the work
mark1a
Post by mark1a » Wed May 08, 2019 6:05 pm
VW manage it at the factory with the SWB, so I would have thought it could be done.
2017 Blackberry Maxi Life 150TDI OEM+
Brescia Clubsport 18” | OE Xenons | Limo tints | Vanstyle side bars | Wind deflectors
H&R / Darkside lowering | TRC front splitter
Android HU | 4G WiFi | Wireless phone charge
envycommercial
Post by envycommercial » Wed May 08, 2019 6:22 pm
The caddy rear seats 100 percent fit in a swb as my pal has them in think there the maxi ones simple to do.
The Touran rear seat isn’t mega difficult I think for me taking it out of the donor was worst bit!
The Touran seats I think are the best ones can run 1 2 or 3 they fold forward and clip in and out in seconds. If you get the rear carpet out of donor that all goes in too, by no means am I a professional at the job but a good day at it and they look like they should be in there.
The brackets do need welding in and the floor pan does need taking up, but it’s only a shelf any way.
Don’t forget to send logbook off and change seats also tell insurance.....
Iv year a rumour that buy fitting the rear seats and altering logbook you can some how get them under a cars tax bracket which if your running a 1.6 is a massive saving how ever I really don’t know if that’s true
Halflife123
Post by Halflife123 » Wed May 08, 2019 7:12 pm
Cheers guys thought that might be the case I’ve been looking at Touran seats and I think I might go that way. Would prefer caddy life seats but they are harder to come by.
envycommercial
Post by envycommercial » Thu May 09, 2019 12:01 pm
I’m taking one out of a Touran tommorow (been putting it off) I’ll see what size drill bit it is.
Just make sure you have a good quality drill bit to
Take spot welds and a hammer and chisel and it’s not difficult to get them out.
If you buy one already out double check it comes with everything, there’s a couple of sets on fleabay advertised as conversions and don’t come with the main part being the floor pan runners.
Get seats belts plastics those 2 Touran floor pan parts etc
And if you can grab the arm rest as well, just as a finishing touch and looks nicer when sat in back!
You also cut your Bulk head to make look nicer from back
I did mine with no guides or how toos as to be fair I didn’t think to check, but there is one I think so use that
Halflife123
Post by Halflife123 » Thu May 09, 2019 5:30 pm
When you say runners do you mean the floor fixing points that need to be welded/bolted where I take out the false floor. And the same sort of thing for the back end of the seat fixings.
