OEM Electric Window Retrofit
owencardew
Post by owencardew » Fri May 10, 2019 12:06 am
Hi Everyone,
Trying to do am OEM Electric Window Retrofit to my 2016 Caddy Mk4. Can anyone assist to provide Part Numbers or Descriptions of all parts required to do this the OEM Way? As far as I can see on Nemiga, Is it just the Motor, Window Switch and electric window loom required? And then coding on VCDS? The diagram on Nemiga shows the loom has a small plug connector on it but where would that connect to?
The other alternative is to use a Conversion kit from eBay, but I am not sure if this would work with the VW OEM Window Switches on the Door Cards I just bought... but most of those don't have One-Touch Control...
Owen
2016 Caddy Maxi 2.0 TDI DSG with RaceChip Pro 2. 18" Santiago Alloys with 235/45R18 Tyres, Smoked Tail Lights, Stainless Steel Pedals. Now installing OEM Bi-Xenon Headlights, Linearus Dash Trim, MFSW & More...
