Injectors help please
Caerwyn72
Post by Caerwyn72 » Mon May 13, 2019 9:33 pm
After some help please, have changed my injector seals and rocker cover gasket seals because the was excessive oil pooling around that area. Now they are new they are doing the same ? Got my parts from TPS and I also gave them the number from the seal. I’m confused now🧐.
sheepy92
Re: Injectors help please
Post by sheepy92 » Mon May 13, 2019 9:36 pm
You may want to check the spill pipes which are the little black rubber/ plastic pipes that go along fuel rail and theres also a plastic elbow clipped into top of each injector o ring seal renowned for splitting and leaking around top of injector
Caerwyn72
Post by Caerwyn72 » Mon May 13, 2019 9:41 pm
Appreciate the reply they seem to be fine the oil comes up around the injectors pools and the returns when engine has stopped. If it is getting a lot of pressure from somewhere?
sheepy92
Post by sheepy92 » Mon May 13, 2019 9:50 pm
The rocker cover plastic breather pipes are also known to make a mess with oil leaking from there that happend on my friends
envycommercial
Post by envycommercial » Tue May 14, 2019 5:16 pm
If it’s a 1.6 there’s a seal around the injector clamp bolt try that?
I managed to snap that bolt when doing mine after being spanked by Volkswagen for 4 injector seals and 4 runner o rings for injectors .. £40 odd quid
dipstr
Post by dipstr » Tue May 14, 2019 6:46 pm
There are two types of seals for the rocker cover injectors. Make sure you have the correct ones as they will leak oil around injectors
