Install Cruise control on Caddy 2011
dynamic duo
Post by dynamic duo » Mon May 13, 2019 9:55 pm
Hi everyone,
I am keen to have a go installing cruise control and MFSW on my Caddy Maxi Life 1.6 TDI (2011). At the moment the steering wheel is basic plastic and the instrument panel only shows the outside temperature and digital km/h. but i know that with MFSW i can get the on board computer to show more information than the outside temperature only. ( I have full version of VCDS Hex-NET).
Has anyone done this before, and how much hassle it is? ( I have installed cruise control before on several of my previous cars ( Audi A2/A3, VW Golf Mk4).
Any advice on parts and installation would be highly appreciated.
Thank you,
Luis
dynamic duo
Re: Install Cruise control on Caddy 2011
Post by dynamic duo » Mon May 13, 2019 10:50 pm
Done some checking with VCDS tonight, looks like I only need a new stalk ( indicator with cruise control buttons) .
Please correct me if I am wrong, but both channel 16 - Steering Wheel and 01- Engine have accepted the coding, thus it means that i do not need any other parts?
Easy enough to remove airbag/ steering wheel and old stalk. Will have a try next weekend and let you all know.
cheers
Post by Doc » Tue May 14, 2019 1:20 am
You'll need the stalk set, nothing else.
There is lots of information in the technical section of the forum on this very subject.
Minimobster
Post by Minimobster » Thu May 16, 2019 11:00 pm
I'm also having a go at this too, hopefully tomorrow, got new stalks and wheel ready, just not looking forward to getting airbag off
dynamic duo
Post by dynamic duo » Fri May 17, 2019 11:21 pm
Hi Minimobster,
as long as you follow the golden rules, removing the airbag is easy.
Just remember to remove the earth from the battery first and before you take the airbag off the steering wheel, touch an earth point so no static is present.
Hi Doc, cheers for confirming :D
r1lea
Post by r1lea » Fri May 17, 2019 11:46 pm
There’s no need to remove the battery, nothing relating to the airbags is live with ignition off
