Caddy speakers in wheel arch box
Chrispope26197
Post by Chrispope26197 » Tue May 14, 2019 11:10 pm
Hey caddy owners,
I’m putting speakers into the wheel arch boxes I’ve made and I was wondering if there’s a howto on where the wiring goes? Obviously I know to take to the back of the radio, but does the normal loom at the quad lock have a wire for rear speakers?
Any suggestions to where to wire them??
stan-the-man
Re: Caddy speakers in wheel arch box
Post by stan-the-man » Wed May 15, 2019 6:26 am
Hey buddy.
You will need to add missing wires into back of the radio plug. You just need to get few female junior power timer terminals and crimp them on wires and possibly will need to change the coding with vcds to enable the rear speakers too.
Depending which caddy and radio you have oem radios pre mk4 Caddy should have sticker with plug connections layout
Chrispope26197
Post by Chrispope26197 » Wed May 15, 2019 9:02 am
I have a aftermarket kenwood stereo! Would I still need coding for that?
Could you link me to the right terminals?
Are they just a push in job?
Thanks for the reply!
stan-the-man
Post by stan-the-man » Wed May 15, 2019 9:07 am
Sure you’ll need something between 1-2.5 wire gauge as I imagine you’re using that’s size of wiring for them?
If it’s aftermarket radio then no coding is required buddy
Chrispope26197
Post by Chrispope26197 » Wed May 15, 2019 9:33 am
No idea mate I can get whatever is advised lol if they’ll do then I’ll get some! Is that all I need to order? Just some female terminals that are between 1-2.5 gauge??
stan-the-man
Post by stan-the-man » Wed May 15, 2019 12:52 pm
Yes as this is is normally speaker wire size used
